Hi guys I have 2 sticks of 1gb crucial ballistix ram.
Windows XP
gigabyte ep35-ds3p motherboard.
I ran a test on crucial and it said my mother board can hold up to 8gb.
I'm upgrading to windows 7 64 bit.
So I ordered this RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
So, if I add those ocz ram, I will have 6gb. Well I am just wondering since (I think) the ballistix and the ocz RAM are different speeds that it might mess/make my comp run more slowly then it should?
I ran cpu-z and it says my DRAM frequency is 533.4mhz. That is the speed of my ballistix RAM right? On the next screen of cpu-z it says pc2-6400 @ 400 MHZ.
I'm sorry for any confusion or mistakes I'm not that great with this stuff, thanks.
Windows XP
