Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > First System Build
First System Build
Forum Systems : Homebuilt First System Build
I wanted to post on here to get opinions and make sure everythings compatible. Also I wanted to make sure I'm not forgetting anything. I havn't decided on any cd/dvd rom drives or floppy drives yet so I'm gonna leave those components out. Also I'm in the middle of looking for a replacement PSU since the one I bought with the case is obsolete.
Case:
Mid-Tower ATX
2 front USB and Audio
PSU:
Need Replacement(suggestions welcome)
Motherboard:
Foxconn ELA LGA 775 Intel P45 ATX Intel Motherboard
CPU:
Intel Pentium E5200 Wolfdale 2.5 GHz LGA 775 65W Dual-Core Processor Model BX80571E5200
Memory:
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory Model F2-8500CL5D-4GBPQ
Hard Drive:
Western Digital Caviar RE2 WD5000YS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive
Video Card:
ASUS EN9600GSO/HTDP/384M GeForce 9600 GSO 384MB 192-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
Sound Card:
Was wanting to use the built in audio on the motherboard instead of buying a Sound Card.
TV Tuner Card:
VisionTek TV Wonder HD 600 900189 PCI-Express x1 Interface
O.S.:
Microsoft Windows Vista Home Basic SP1 64-bit for System Builders.
All the components were found on newegg.com
Reply to Upgrade30
Yes everything is compatible but it's not all that powerful of a build... not sure what you're using it for but if you give us your budget it might be possible to build something a little more powerful. As for the optical drive it's not really that important I usually just a buy a cheap drive from Lite-On with good reviews. Floppy drive... not needed. Finally, I would recommend buying a motherboard from a different manufacturer if possible e.g. Gigabyte, Asus, DFI, MSI, etc. Hope this helps.
Reply to jbakerlent
My budgets around $500-700. I almost forgot I still gotta decide on a network card. Most likely its got to be wireless. I'm wanting to build the system for gaming and internet surfing mainly.
Message edited by Upgrade30 on 07-16-2009 at 03:16:15 AM
Reply to Upgrade30
In that case I would recommend a build based around and AMD Phenom II 550... Check it out and let me know if you want me to pick out some more parts for you. It makes and amazing gaming PC when coupled with the right graphics card.
Reply to jbakerlent
- 0 +
I agree with jbakerlent. With that budget, you can build a much more powerful computer if you choose AMD.
Reply to JDV28
I've checked out the specs on an amd phenom II x2 550. But I'm having troubles finding a good motherboard/video card combo I'm happy with. Anybody with experience with the phenom II x2 550, I'd like to ask for an opinion on both the mobo and video. This is my first system build so I would like all the components to be relatively easy to install. Here's a link for the processor [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16819103680&Tpk=amd%20phenom%20II%20x2][/url]
Reply to Upgrade30
Looking up motherboards I found a pretty good combo cpu/mobo deal on newegg.com. The CPUs a Phenom II x3 720.
http://www.newegg.com/Product/Comb [...] mbo.205337
Would you recommend the Combo over the dual-core processor and an average mobo?
Reply to Upgrade30
Yes, that combo looks like a good deal...
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
There are 2136 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Making a new build
By imranfarid99, 1 hour ago:
You have Gone for a crappy PSU...................avoid it dont risk your entire PC on...
Best offers
Top experts
