dvd drive makes strange noises and doesn't read disks smoothly
  • Laptops
  • DVD Drives
  • Components
Last response: in Components
October 15, 2009 7:30:40 AM
My slimline dvd drive on my laptop makes strange noises and doesn't read disks smoothly. It will read disks eventually after lots of 'unusual whirring' I know the noises it makes when it normally reads a disk. It also doesn't load programs smoothly. I know there is obviously something wrong with it but are there any solutions other than replacing it? Maybe changing the driver?
I can't reinstall the driver as I don't have a driver to reinstall it with afterwords.
Any ideas?
More about : dvd drive makes strange noises read disks smoothly
October 15, 2009 4:10:58 PM
Windows should automatically detect it after a reboot if you do remove the device.
But, it sounds like the drive is dying. I suggest a thorough cleaning or get another one :)
October 15, 2009 4:49:51 PM
can I just get any other laptop dvd drive and it will fit? do I have to make sure that it is a slimlin drive too?
April 12, 2014 11:14:27 PM
no you dont have to make sure its a slimline drive.... make sure you clean it thoroughly first and if the problem persists change the drive...
