Ram running under 40% at full speed
Hello, my computer is very slow and my ram is never even reaching 40% of it's capacity. I took the CPU-Z tool to see my cpu's infos and that's what i got :
DRAM = 266 mhz
fsm = 1:2
4clocks,4clocks,4clocks
12 clocks
*** i got a 3072mb(3gb) ram intel pentium t2390 (dual-core)1.86ghz.
core speed = between 1860-70 mhz
multiplier = 14X
bus speed = 133 mhz
rated fsb = 532 mhz
If I take some advices i found on this site, clocks should be doubled and the dram frequency too.so that would give me DRAM = 533mhz (x2 = 1066mhz)and clocks should be 8-8-8 24.
I just wanted to know is this is right and how to change these settings. Must I have to go in the bios at startup and if yes how.
here are screenshots in case you'd need some more info
http://flic.kr/p/abaGTR
http://flic.kr/p/abaGVn
More about : ram running full speed
Related ressources
Memory Master
Overclocking Master
Your RAM is running at 533MHz with CL 4-4-4-12 dual channel, everything is fine.ยก and you don't need change anything.
The only thing that is double in dual channel is the frequency, the timings are the same for both, single and dual.
well ok .... what should i do then to make my computer faster , it is very slow and there is no reason to it like i said its running under 40% of its ram capacity when running at full speed
only raise up the ram frequency to 533 to double it to 1066ghz without changing clocks will do it ? ram should then run about 80% of its capacity and make my computer twice faster?
if not i dont know what to do aint you'd got a soluce
Ask the community
