I have this kingwin 730 watt PSU. I'm having problems with games in full screen getting artifacts when sli is enabled. I'm thinking maybe I don't have enough power? My question is my power supply powerful enough to support my system?
System Specs:
Core i7 920
6gb ddr3 1333
2 GTX 280's
640GB WD hardrive
NEC DVD burner
MSI X58 Pro-e mobo
or does anyone know what may be causing the problem? I get no artifacts when disabling SLI or when i run the game in a window instead of fullscreen.
Try each card one at a time and see if one of the cards are faulty. Its possible your temps are to high with both cards under load. What are temps? Can you give exact model of psu.
Yes sorry I forgot to mention that I've tested both cards independently and they are both working perfectly. PSU: KINGWIN ABT-730MM 730W ATX 12V Ver.2.91 SLI Ready CrossFire Ready Active PFC Power Supply. newegg link: http://www.newegg.com/Product/Prod [...] win%20730. temps are around 40 idle and 65-70 load
Try to reinstall drivers and see if that help. Do you have an extra psu you could use to test if your psu is failing to power the cards?
I'm currently on forceware 190.38 which i've reinstalled a couple of times but nothing changed. What do you guys think about either going to an older driver version or the beta 190.40? unfortunately no i don't have any extra power supplys. Any other suggestions?
I've solved this problem! I shut down my pc removed my SLI bridge powered up and no longer have any artifacts or graphic glitches and have the same FPS as I did with the bridge.
Faulty bridge perhaps? Do you have another bridge that came with the other card you could try? Really you should have the bridge on there since that's what syncs the cards together.
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
I guess it must be faulty although I do not have another bridge to test out. Really disappointed if the bridge is faulty since I had to order it off ebay because neither my cards or mobo came with a sli bridge.
I'm using a dvi to hdmi adapter to hook up to a sony 40 inch hdtv. i noticed that the dvi adapter has fewer pins than what looks like should plug in to the dvi input on the card. could this have anything to do with my problems? I'n just making stabs in the dark here.
Even if the sli bridge is faulty no reason for artifacts. I ran my runs without the cable. Only affect lower fps but no crashes or artifacts. Psu problem in my opinion now.
Message edited by invisik on 08-06-2009 at 03:30:41 PM
Something else that's interesting, when i record the game getting artifacts using fraps the raw video shows no artifacts or graphic glitches. THIS post describes my exact problem. The poster resolved that removing the bridge was the only thing that worked for him and so far is the only thing that's worked for me.
just got my new psu, hooked everything up and..... still having the same problem with artifacts and color flashes, F my life. this eliminates the possibility of psu being the problem any more help?
