Sign-in / Sign-up
P193 + Power Supply
  • Power Supplies
  • Cases
  • Components
  • Product
Last response: in Components
October 15, 2009 2:45:52 PM
I'm trying to find a power supply that will mount in the P193 and have the CPU 8-Pin connector reach clear across the case as the 8-PIN is almost flush against the top of the case (tried an OCZ model and it falls short even with no cards mounted in the case). Any recommendations on a PSU with long power cables? Looking in the 600+ Watt range.
Thank you in advance.
More about : p193 power supply
a c 246 ) Power supply
October 15, 2009 3:41:18 PM
If you already have a power supply, then all you need is an 8 inch psu power extension cable available for a couple of dollars at online vendors.
Here is a link to an example:
If you still want to purchase a power supply, then please list your pc components so we can make valid recommendations.
October 15, 2009 9:07:21 PM
Thanks Johnny, not quite sure why I didn't think of that.
October 15, 2009 10:43:08 PM
You're welcome.
October 11, 2010 3:40:34 AM
the cooler master Real Power Pro 1250W Power Supply
1250 continuous power supply will fit since I am using it the p193 case, but the power supply is 299.99 plus tax. and you need at least a 15 amp dedicated breaker/fuse. it has a sticker on it saying 16a wiring, but no one has that except if you go on a 240volts. but most people using 125 volts.
look up this power supply, you will not be disappointed.
http://www.coolermaster-usa.com/product.php?product_id=...
it is an overkill but you wait and see how many hard drives you will have after you have your p193 case installed.
October 11, 2010 11:33:03 AM
The CP-850 that Jack recommended I support fully when using one of the Antec cases that fits it.. It was big, VERY big but it was easy to work with and the semi-modular design suited my needs nicely (so take a look, at that price point you probably won't find anything competitive)!
