Hello I have a pc with a pentium 4 3.0 ghz cpu, 1,5 gb Ram ddr1 and windows xp service pack 3. I bought this pc 4 years ago. Last month i tried to turn the pc on and there wasn't any signal at the screen. When i tried to reset, it started at once but gave me the message "overclocking failed!press f1 to enter bios or f2 to load default values and contunue". Weird thing is, i didn't try any overclocking and i didn't find any change at the "overclocking" value in bios. So, I just quit and the pc continued loading, but the cpu speed was much lower than before. Every single program loads much slower since then, and at the ctrl-alt-del screen i see that it takes a big share from the cpu (firefox for example may use 100% of cpu to load a single page). Every time i turn the pc on since then, i experience the same problem. Some times,also, just resetting won't make the pc continue loading, but i should reset many times before it eventually beeps and shows me the "overclocking" message. I thought it was a power problem, but i was told that it may also be a problem with my motherboard. What should I do?
Right click My Computer and see what windows is reporting the CPU speed as.
It's possible the cpu has failed and won't run at normal speed. Double check the bios settings and make sure any multipliers, bus speeds, or memory speeds haven't changed.
------------------------------I ain't signing nothin
Reply to sturm
reported cpu is 3.0 ghz, the right one. And i see it also in dxdiag and bios. So it figures it is not a cpu failure. But why do i get the "overclocking" message?
