Wireless only works in safe mode
Last response: in Windows XP
Related ressources
Quote:
Post the output from ipconfig/all here when your computer is in Safe Mode & Normal Mode.
It is like this on both connections but in normal mode it disconnects after a few mins sometimes.
test.txt
C:\Documents and Settings\K.K-953208E7>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : k-953208e7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : gateway.2wire.net
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Co
roller
Physical Address. . . . . . . . . : 00-16-D4-E0-99-6F
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : gateway.2wire.net
Description . . . . . . . . . . . : Broadcom 802.11g Network Adapter
Physical Address. . . . . . . . . : 00-19-7E-A9-9F-3B
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.2.12
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DNS Servers . . . . . . . . . . . : 192.168.2.1
Lease Obtained. . . . . . . . . . : December 30, 2011 5:02:39 PM
Lease Expires . . . . . . . . . . : January 2, 2012 5:02:39 PM
I turned off SKype's port 80, could that be it?
Not sure why it would have worked before and not now though.
If it blocks again, I am going to try a netstat -aon and compare the PID with the PIDs in the task manager.
Your ipconfig /all results, specifically DNS Server and Lease acquisition - expiration date, show your computer is connected to the internet, the problem may be Winsock corruption.. to repair it Download "XP TCP/IP Repair 2.1" from http://www.xp-smoker.com/freeware.html.
Use the TCP/IP reset button and restart the computer... and next use the Repair Winsock button and restart the computer again.
As far as I know, port 80 is the default port for Internet Browsers, so it's possible that caused your problem. Enable port 80 and assign another port number for Skype in the Windows Firewall.
qwertyjjj said:
Stopped working again.
However, nothing seems to be bound to localhost:80.
Email works though.
Any ideas?
E-mail through an email client? (Outlook, Outlook Express, Thunderbird?)... the difference between Internet Browsers and Email Clients are the ports they use to connect to the Internet. Have you added an exception for port 80 in the Firewall?
Default Ports for Email Clients: Pop, Imap, w/wo SSL
http://hostbaby.org/wiki/Default_Ports_for_Email_Client...
my HTTP port 80 internet connection won't work
http://www.daniweb.com/hardware-and-software/microsoft-...
Ask the community
