Do these compression fittings work with my tubing?
Hi guys, im getting this tubing and have ordered these compression fittings. Just wanted to know if i have made a good choice for the fittings? I noticed that the fittings are both 11 and 12mm?
Thanks!
2 answers Last reply
More about compression fittings work tubing
  1. Your URLs are broken.
  2. yes. The tubing is 7/16"ID and 5/8"OD, and the compression fittings you chose are designed for that size.
Water Cooling Compression Overclocking
