Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Toshiba Satellite Pro 490cdt power-off on cd read
Forum Laptops & Notebooks : General Laptops & Notebooks - Toshiba Satellite Pro 490cdt power-off on cd read
Archived from groups: comp.sys.laptops (More info?)
i found an ancient laptop in my basement last night. the battery is no
good, there is solder on the prongs from when it was last used
(mid-late 90's) showing problems with it then. it does boot up if
plugged in to the wall via a 15v ac adapter, but if there is a cd in
the cd-rom drive, the LCD screen will light up with the toshiba logo
for a moment but then power-off immediatly. if you boot into windows
(95, by the way) without a cd in the drive and then insert one, the
laptop will immediatly power-off.
the screws are all stripped so i cannot find a way inside short of
prying it apart (which i don't think i'm going to do). everything else
seems in working order. the computer will not power-off if a device is
inserted into one of the drive bays.
i have no experience with laptops, but a good amount with desktop pcs.
any help is appreciated.
matt ross
Sponsored Links
There are 961 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
