I was wondering if anyone could tell if my PC cooling method is any good. I have been working on trying to get my temperatures to get as low as I can. The temperature in my room is pretty cool but I do not know the exact temperature although I do know the temperatures of my components.
*The temperatures are located in one of the pictures I have posted*
The case that I am currently using is the (ExtremEngine 3T PC Case).
I was also thinking about cutting out a hole at the top of the case and fitting a fan there to get more heat out.
Basically I just need to know what you guys think of my cooling.
NOTE: I have also overclocked my CPU (Changed the multiplier but I have not seen any difference in CPU temperature change). I have overclocked my video card too, so that obviously gets a little bit warmer but not by much.
*this is also my first thread that I wrote, so I'm sorry if I have made a mistake. If I have made any mistake, be sure to tell me so that I don't screw up next time. Also, if you guys need any more information to make a reasonable assumption about my system, please let me know.*
Thanks for any help provided.
Here are some pics of my system:
