Tom's Hardware > Forum > Homebuilt Systems > New System Build > I need a fast $600 system build....help?
Forum Homebuilt Systems : New System Build - I need a fast $600 system build....help?
Question: Can you build me a fast computer for around $600ish?
Uses from most to least important: Multitasking---- Recording and producing Music, gaming, audio, internet, student applications (microsoft word etc...)
Preferences: I am interested in doing crossfire, not sli. Don't really care what brand...amd or intel. Whatever will work the best. I need firewire on my motherboard. I will use either XP or vista 32 bit. Most likely vista.
I would like quad core if thats possible...but that might be unrealistic for this budget.
To be more specific in my recording epuipment, i have an M-Audio profire 610 audio interface (sound card) and i will be using Sonar 6...eventually i will get Sonar 8. And i have studio monitors...so i got those parts covered :)
I want it to be as fast as possible!!!! thank you in advance :)
Sponsored Links
Why do you have preference on crossfire/sli??? they simply are the same set up but with different brands of video cards?
With regards to a budget build the Phenom 550b or 720be maybe a good idea for cpu.
I am in the UK but believe that new egg have some good combo deals at the moment might be worth checking out.
Reply to pij
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
