I have an AMD 4400+ machine with ASUS motherboard, 2GB DDRII, 80 GB SATA HDD Seagate. My OS is Windows XP 32 bit.
My system is continuously restarting. I have checked my OS, tried re-installation, cleaned up my RAM and put it all together. Still the problem is there.
Please help me with this problem. Whats the next thing i should do??
if this is a new sytem you just built you probably have a short . Either one of the mb stand offs are in the wrong place , or the case reset or power switches are bad.
