I'm following the guide in the sticky, and I had some questions about all this disabling and enabling certain features. I researched a few of them and some of the settings I might want to keep unless I can't hit a certain clock with them. I was hoping I could get some help OC'ing while catering to my preferences.
I want to OC as high as possible while keeping the lowest voltages possible. Also I would like to have turbo boost enabled so I can idle at 1.6GHz when browsing and whatnot. I have the AsRock p67 extreme4 mobo. Thanks in advance.
Basically I'm wondering why one overclocking guide has certain settings disabled and another guide has settings enabled. In the guides it just says Do this... and doesn't say why.
Right now I have spread spectrum and c1e support disabled and Internal PLL overvolt enabled, with a multiplier of 45. But in CPUID my CPU is only reaching 3.9GHz, why would this be?
I have used the BIOS Preset for 4.8GHz before and that worked fine, so I know my CPU can reach at LEAST that high of a multiplier.
