Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > SPDIF connection on GTS 250
Forum Graphic & Displays : Graphics Cards - SPDIF connection on GTS 250
Hi, I have a ECS GTS 250 ( http://www.newegg.com/Product/Prod [...] 6814134064 ) and I recently purchased an HDTV that I'd like to hook up my computer to. The easiest way would be with a DVI-HDMI converter which was included with the card to the HDMI port in the TV. My problem is with hooking up the sound to the video card. It came with the cable to do it, and the side that connects to the card is pretty obvious, but the other side is just 2 single pin connectors and I'm not sure exactly where they should go. Im trying to connect it to a Creative Sound Blaster X-Fi Titanium Fatal1ty Professional ( http://www.newegg.com/Product/Prod [...] 6829102019 ). Thanks for the help.
Sponsored Links
Read the manual and look for the SPDIF connector on your Fatality.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
You can't get audio out of a DVI->HDMI cable/converter. There are no audio pins on a DVI connector. At least as far as I know there aren't. I'm not sure why a video card with out an HDMI port would even have a digital audio connector.
Your best bet is to use a separate cable to carry the audio from your sound blaster to you receiver.
Reply to JasonAkkerman
Wow, apparently some video card manufactures have changed the DVI standard port to work with their DVI->HDMI converters so that you can get sound.
Which begs the question, Why not just put the damn HDMI connector on the board?
The manual from the video card is in no way helpful, since for the last step it says "If user adopts the HDMI application, pls make sure your SPIDF cable connect to the VGA card & MB properly." It also shows a picture of where the cable goes on the video card, as if it wasn't obvious enough. The only mention of the internal pins on the sound card's manual is for a 10 pin front panel Intel HD sound connection. However there is a whole other set of pins located on the back of the card which as far as I know are not mentioned in the manual.
I wouldn't have a problem just running a cable from the sound card directly to the TV for the sound, but I'm under the impression that since it connects via HDMI the TV will be looking for sound from that connection and not recognize a secondary source.
Reply to pyro006
What are you on about?
DVI can't hold audio!
Reply to amdfangirl
Go to creative web pages. There is an SPDIF connector on the XIFI Card. You can connect the SPDIF from XFI to your video card. The diagram you need to dig out on the creative web page. Some how i lost the pdf file. You will find it...
On the control panel audio option select SPEAKERS (creative SB_XFI)
On the creative consul launcher , Encouder Settings, Select Dolby Digital. Click Settings and Select SPDIF.
I have done this on my BFG GTX 280 and XFI cards and get the sound to come out on the HDMI.
BFG send me an DVI-HDMI converter, SPDIF cable, and HDMI cable. This is the same case as you indicated on your video card. You should get a sound from XFI to your Video card.
Reply to leon2006
+1 that is correct. As long as you connect the 2 pin spdif connector to the sound card and the video card the dvi to hdmi adapter will carry an audio signal.
Message edited by chef7734 on 08-09-2009 at 07:54:13 AM
------------------------------ MSI x58 eclipse plus/ i7 920@ 3.66/ 3x2gb ocz ddr3 1600 platinum/ 3x xfx gtx 285 black edition/ velociraptor 300/ wd 1tb black / lg GGC-H20L/ GBW-H20L/ Cosmos S/ Corsair HX1000
Reply to chef7734
There are 789 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
