Hi,
Just wanted to find out. If a PSU comes iwth 2x 8pin and 2x 6 pin, is it possible to connect the 8pins to a GTX 285? ..... i.e. if you were to connect that PSU to two GTX 285 in SLI and you only had 2x6pin and 2x8in, will it fit? OR do you need 4x6pin? ...
http://www.ebuyer.com/product/161664 this is the PSU I'm talking about specifically.
thanks
thanks
