Computer won't turn on. Power supply is okay. Is the motherboard bad?
I'm going through the steps in this tutorial (http://pcsupport.about.com/od/findbysymptom/ht/nopowert...) to deal with a system that will not turn on. I got past the power supply, where I managed to test all of the pins for the proper levels. I didn't check the power button because I'm afraid of hitting the wrong pins and damaging my board, although I will if I have to.
My next step was to check my motherboard by buying a POST card, but I'm hesitant if there is another way or if buying one will put me out more than it's worth. Is there anything else I can check? Is buying a POST card worth it for fixing one system?
BTW the board is an Asus M2N MX SE.
More about : computer turn power supply motherboard bad
Related ressources
- New power supply slimline wont turn on - Forum
- Bad power supply ? - Forum
- My new home built computer won't turn on - Forum
- PC wont turn on. How to find out if PSU, motherboard , or CPU is bad ? - Forum
- If the power supply is okay but no bios loading - Forum
pjmelect said:
I don’t think that a Post card will give you any meaningful information, so I would not buy one just to test this system, the money would be much better spent on a new power supply as this is probably the fault and if it isn’t then you have a spare for when it does go faulty in a few years time.Well, when I tested the PSU, I think I followed the tutorial fairly well. All of the pins are within range. But I'm new to this so I might have done something wrong.. Are there more thorough tests one can do?
If you want to test if the motherboard is working. ( you need a motherboard speaker) Take out all of your ram then turn it on if you hear a beep then your motherboard is ok if you don't then your motherboard has broken.
This worked for me and I went out and got a new motherboard then it was fine.
hope this helps
from
Jordan
hope this helps
from
Jordan
I am reading this, and I hear you say that you do not want to try to start the board by shorting across the 2 power pins. However, you state that you are certain the power supply is not bad, because you have tested each of the power supply leads with a tester. Your statements lead me to believe that your assessment of your PSU may not be conclusive.
A motherboard speaker, so you can listen to beep codes, is a must for troubleshooting these things. You can buy one for like $5.
aford10 said:
What model is the old and new PSU? What kind of video card?Make sure the 4/8 pin CPU power is plugged in.
Do you have a motherboard speaker?
Randomly buying parts isn't the best way to tackle this. There are some ways to help narrow it down.
Sorry for the confusion, yesterday I ordered a new PSU for another system, not this one..
The videocard is a GeForce 7200 GS. The 4 pin CPU cable is plugged in. I checked with the multimeter yesterday and it seemed okay. A far as a mother board speaker, I think I've heard it beep before, but I can't quite remember.
Look near your front panel wiring on the motherboard. The motherboard speaker will look like this
http://img.auctiva.com/imgdata/1/3/1/4/5/3/2/webimg/315...
If you don't see something that looks like that, you may want to get one.
aford10 said:
Look near your front panel wiring on the motherboard. The motherboard speaker will look like thishttp://img.auctiva.com/imgdata/1/3/1/4/5/3/2/webimg/315...
Nah, I don't have one.. I'll probably have to go downtown and pick one up today.
jitpublisher said:
I am reading this, and I hear you say that you do not want to try to start the board by shorting across the 2 power pins. However, you state that you are certain the power supply is not bad, because you have tested each of the power supply leads with a tester. Your statements lead me to believe that your assessment of your PSU may not be conclusive.A motherboard speaker, so you can listen to beep codes, is a must for troubleshooting these things. You can buy one for like $5.
I followed this tutorial (http://pcsupport.about.com/od/toolsofthetrade/ht/power-...). Checked the motherboard and CPU pins. I don't have a hard drive connected to this machine so there were no others to check. But like I said I'm new to this so I might have made a mistake somewhere, so might try it again, going through it more carefully.
Here is a simple thing that might help. I thought I had a motherboard issue similar to yours, no signs of life except fans. Change the clock battery. I did this and my computer started right up. It's funny how no one seems to come up with that answer. ASUS was ready to RMA mine, but I found my own solution. Hope it's not too late to help
I got my motherboard speaker in the mail on Friday and decided I'd try it out right now. I downloaded the manual for the motherboard and I think I have the right pins.. I turned it on and.. nothing. No beeps. I pulled it out and flipped it around and still nothing. I'm going to look up the clock battery and give that a shot.
did changing the clock battery work?
Have similar problem,PSU tests ok when isolated,but PC wont turn on when connected to mobo and peripherals
robinhoode said:
I got my motherboard speaker in the mail on Friday and decided I'd try it out right now. I downloaded the manual for the motherboard and I think I have the right pins.. I turned it on and.. nothing. No beeps. I pulled it out and flipped it around and still nothing. I'm going to look up the clock battery and give that a shot.kastor900 said:
I had a similar problem but i had to take out the graphics card and run start-up on internal motherboard display. Try that@kastor900
Where exactly do you think the internal MoBo display wille be situated on a Asus m2n -sli de luxe.
I personally do not think there is one on this MoBo, so what do you suggest instead?
Sometimes, windows system files such as bootmgr/ntldr is missing can due to your computer won't boot, you can download Fix Genius from http://lnkd.in/CcR755 to check and repari the losing file.
robinhoode said:
I'm going through the steps in this tutorial (http://pcsupport.about.com/od/findbysymptom/ht/nopowert...) to deal with a system that will not turn on. I got past the power supply, where I managed to test all of the pins for the proper levels. I didn't check the power button because I'm afraid of hitting the wrong pins and damaging my board, although I will if I have to.My next step was to check my motherboard by buying a POST card, but I'm hesitant if there is another way or if buying one will put me out more than it's worth. Is there anything else I can check? Is buying a POST card worth it for fixing one system?
It could be that the heatsink fan is not properly seated on the CPU or that there is not enough thermal paste (also, too much thermal paste will not allow heat transfer through to the heatsink).
If the PSU is less then 300 watts then that could be a problem.
I had similar (not exactly same) but similar, and I solved this way:
MY COMPUTER WAS NOT TURN IT ON- AT ALL
- I took cables away (every cable) from the mobo
- After that -no cables connected except the 24 pin- I connected the power supply and turn it on and it turned on!
- I realize then that I have a short circuit problem-
- I put back each of the cables- one by one, and at same time turning on the PC to see where the problem was.
- When it was the time to connect one of the cables to the mobo I turn the PC on but it did not, so I realize that it was the problem- (one of the cables had short circuit)
- That small cable was the big problem, and was only a led cable -not so important for the PC to work-
- So I disconnected that cable and not used anymore- and my PC is fine now.
SO THE LESSON is: when you install cables in the MOBO I believe you have to be very careful- cause can cause a short circuit. And in order to diagnose properly you have to do it ONE BY ONE step.
Related ressources:
- ForumSimple and Free Guide to Removing Malware
- ForumPower Supply wont turn on when connected to Motherboard
- ForumComputer won't turn on..?
- ForumIs it okay to mount a power supply upside down in a computer case?
- ForumFriend has New Power Supply , 20+4 pin won't fit
- ForumMy old PC won't turn on. I think it may be power supply related.
- ForumLow budget build - Is this okay ?
- ForumComputer wont boot without turning power supply off and then back on
- ForumBad motherboard or PSU? Won't POST
- ForumBad motherboard , power supply , ram, CPU?
- More resources
Read discussions in other Motherboards categories
I'm debating if buying a new PSU is worth it.. And what to do if that doesn't hep.. It would be the second one I bought today!
