Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help building my own computer
Hey guys... I was thinking of getting a pc on cyberpowerpc.com but thought they were a little pricey. So I decided to build my own. My budget is $850 so I might not be able to get the best gpu ang cpu out there but oh well. I would use the pc for gaming (battlefield 2142, left 4 dead, left 4 dead 2, crysis, crysis 2, and others) Tell me your suggestions for parts.
I want a quad core pc and ddr3 ram.
As for my videocard I would like to upgrade to SLI or Crossfire when I get the money. I would prefer Nvidia because most of the games I play prefer NVIDIA.
Was also looking at the GTX 260 or GTS 250.
All of the parts will most likely be from newegg.
Tell me if you need any more details.
Sponsored Links
EDIT: Also, Is it tough building my own pc? I am kind of a newbie but know most of the ropes.
Reply to jdelsignore911
Please edit your post using this format
http://www.tomshardware.com/forum/ [...] ild-advice
as we need to know monitor resolution, uses, overclocking etc.
Reply to hunter315
Purchase Date: Near Future (3-4 weeks)
Usage: Gaming
Parts not needed: nothing need everything... Building from scratch
PREFERRED WEBSITE(S) FOR PARTS: Newegg
PARTS PREFERENCES: Would like a NVIDIA gpu, and dont really care about the cpu.
OVERCLOCKING: Probably no. Have never done it. Dont even know how.
SLI/Crossfire: Yes in the future when cash is plentiful
MONITOR RESOLUTION: 1600 x 900
Already have monitor selected at best buy, but will check at newegg to see if it is cheaper.
Usage: Gaming
Your budget is $850, but does that include the monitor, keyboard, mouse, speakers etc.?
Reply to g3force
My budget of $850 is the max for the pc itself.
Already have mouse and keyboard, monitor, speakers...
Try to make it around $800
what monitor has a 1600 x 900 resolution?
Reply to Outlander_04
What resolution should I get?
http://www.bestbuy.com/site/olspag [...] 8061081362
We dont have any 1600 x 900 res monitors available here .
Generally LCD's have been
1440 x 900
1680 x 1050
1920 x 1200
but I guess other resolutions are starting to appear . Hopefully the gfx card drivers support those resolutions
For the same price as the OP's bestbuy lcd
he could get
a 22inch 1680 x 1050 from newegg
http://www.newegg.com/Product/Prod [...] 6824236050
Antec 300 Case
http://www.newegg.com/Product/Prod [...] 6811129042
Antec 650W PS
http://www.newegg.com/Product/Prod [...] 6817371015
WD Caviar 640Gb HD
http://www.newegg.com/Product/Prod [...] 6822136218
Gigabyte EP45 UD3P Mobo
http://www.newegg.com/Product/Prod [...] 6813128358
G.Skill 2x2Gb DDR2 800Mhz, CAS4 Ram
http://www.newegg.com/Product/Prod [...] 6820231209
EVGA GTX 280
http://www.newegg.com/Product/Prod [...] 6814130492
Intel Core 2 Quad E9550
http://www.newegg.com/Product/Prod [...] 6819115041
Xigmatek Rifle Heatsink
http://www.newegg.com/Product/Prod [...] 6835233005
With rebates and whatnot it will cost you around $850. The graphics card is a lil overkill for your purposes, so you could downgrade to a gtx 260 and save $75 if you wanted.
Reply to snurp85
Thanks dude I'll check it out.
snurp85 wrote :
Antec 300 Case
Antec 650W PS
WD Caviar 640Gb HD
EVGA GTX 280
I was wondering if a mobo has crossfire does it have SLI? And I was leaning towards ddr3 ram.
Only with an X58 (LGA 1366 Socket) board will you have the option for Crossfire and SLI. All other MOBO's are either Crossfire or SLI.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Thanks. I will be using SLI then because i want 2 gts 250 or 2 gtx 260. So that I guess narrows it down.
Now that i have read a little about overclocking it sounds pretty cool.
Does overclocking help your computer go faster or does it allow you to run more things like the concept of ram.
ram=Files only use so much ram so putting 8 gigs in your pc wont benefit anything until there are files and programs that use 8 gigs.
So the question would be does a game use all of the speed or just what it needs?
Yes I will most likely overclock once i find out how to.
There are 1243 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
