Tom's Hardware > Forum > Homebuilt Systems > New System Build > Been awhile since I built a system, mainly play wow... advice welcomed
Forum Homebuilt Systems : New System Build - Been awhile since I built a system, mainly play wow... advice welcomed
Hi all, let me start by saying it's been a few years since I have built a rig for myself. I think I have a decent "paper" build but like others I'd like some advice... thanks in advance
*ahem* here's the list
Case- Antec P193 Gunmetal Gray Aluminum / Steel / Plastic ATX Mid Tower Computer Case
I'm worried about fan clearance with this case, if anyone has recommendations that support the vid card I'm wanting I'm all ears.
Power Supply CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
Processor- Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
I've read that WoW is more processor speed dependant than the amount of cores, thus I'm saving a little money and going with a faster dual core that I intend to overclock
Processor Fan- ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
I'll probably be using arctic silver thermal grease on this.
Motherboard- ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 ATX Intel Motherboard
Anyone know if this board is overclocking friendly?
RAM 4gb mushkin ddr3 1600
Video- ASUS EAH4890 TOP/HTDI/1GD5 Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Hard Drive- Western Digital Caviar Black 1tb
Pioneer Blue-Ray rom/dvd burner
Purchase date is in the next couple months hoping to keep the tower under 1400ish
Usage is mainly WoW, also watching tv I have an adaptec avc 3610 for a tv tuner
Parts not required, Monitor (I have a 46" sharp aquos that I will be using for a monitor) Speakers (have a home theatre setup) Keyboard and Mouse and Tv Tuner.
I've been looking at newegg for parts, I've dealt with them in the past and had good experiences.
I'm going to be overclocking, and eventually will probably upgrade to crossfire.
Thanks for your time and any thoughts.
Sponsored Links
dual core and ddr3??only I7 procesors benefit from triple channel>>also,less money for the case and more for your main components, you have a good idea of what you want but there isnt any build that cant be improve, 775 socket is almost dead, and your upgrade path is going to be replaced by new 1366 socket, I think you better of with Phenom II, i have the 955 and its a beast, as good as the q9550, if not better. how about this:
http://www.newegg.com/Product/Comb [...] mbo.212581
http://www.newegg.com/Product/Prod [...] 6820227320
http://www.newegg.com/Product/Prod [...] 6814121311
overclocking and cheap dont mix, you need a better HSF than the artic 7
http://www.newegg.com/Product/Prod [...] 6835185093
you where spending way to much on a case, chances are you're gonna have less performance for better looks, dont think so, you can have both
http://www.newegg.com/Product/Prod [...] 6811119196
850 watt is an overkill for a single 4890 unless you planning a CF so how about
http://www.newegg.com/Product/Prod [...] 6817273008
unless you are going to use the pc as an storage build i dont think you need 1t
how about 640 caviar black ( http://www.newegg.com/Product/Prod [...] 6822136319 ) it has 2 320 plates which makes it quite fast
blue ray?? well its your go but a nice dvd burner will have been better if you ask me
http://www.newegg.com/Product/Prod [...] 6827129016
Subtotal: $1,086.92
Grand Total: $1,100.83
Message edited by snakej on 07-20-2009 at 12:48:12 AM
Reply to snakej
- 0 +
Hi,
The build looks solid to me. I would recommend spending a bit more on the CPU cooler though, that one is ok, but not for overclocking. For socket 775, the zalmans are pretty nice (cnps 9700) but a bit pricey, and Zigmatek has some nice ones in the $40 price range.
Reply to buzznut
- 0 +
Since you're not building for a couple months, I'd put the paper build on hold and wait till i5 gets released. Prices will change a lot when it does come out, both on the AMD and intel side. With the budget you have, you are going to get WAY more computer than you need for WoW and HTPC apps. You should be getting at least a tri core if not a quad anyway if you are going to CF or SLI (which is an option if you get an i5 system.)
If you are going to move forward with this build though, 850w PSU is overkill. 4890 CF will do fine on a 600w corsair, so to be safe, the 750 would be a good match for you.
Before I picked up an E8500, I would take a good look at AMD Phenom IIs. Reason is the upgrade path is there in the future if you need it where, as mentioned, the Core 2 is end of life.
+1 to the Xigimech HSF
Mobo will follow the CPU choosen and I'd vote you pick a different platform.
There's cheaper 4gig dual channel DDR3 kits that are Cas 7 with 7-7-7-18 timings. GSkill or Curcial I think.
The 4890 is a great card. You'll have no prob destroying WoW for the next decade with that. So unless there are other FPS games you play, I wouldn't worry to much about CF. That being said, the GTX 275 is also a great card in that price range. If you i5, then you have the option to SLI.
And don't for get an OS.
Message edited by skora on 07-20-2009 at 01:52:33 AM
------------------------------ TheAnimal's - HOW TO ASK FOR BUILD ADVISE - Use this FORMAT
sKora's Design Guide
Reply to skora
- 0 +
agree 100% with skora, if you dont need the build right now, either because you need time to get the money, or what ever other possible reason< i recomened putting this project on hold,
as skora said core i5 release is almost at the corner ( http://news.cnet.com/8301-13924_3-10266536-64.html )
and also the release of the new GPU's direct x11 capable ( http://techfragments.com/news/857/ [...] _Card.html )
if you cant wait, and are ready to build in the next 1 to 2 weeks, then PII is the only option, or either get enough money for an i7 build.
Reply to snakej
There are 1192 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
