Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Card vs Integrated
Forum CPU & Components : Sound Cards - Sound Card vs Integrated
I have this old sound card lying around http://www.newegg.com/Product/Prod [...] 6829102190 and this is my motherboard http://www.newegg.com/Product/Prod [...] 6813188046, since it's old and I've never used it I was curious whether or not it would be better than the integrated sound in my newer motherboard?
Sponsored Links
Your onboard sound will be better! I have the same board and my sound is just fine and doesn't require an additional sound card.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
use the sound card, first its a creative, and if you do any gaming well thats mostly the only thing they do now... plus onboard sound uses more system resourses that you might need for something else... thats the advantage of having a processing unit just to process sound in the add-in sound card ;) (at least in the good ones such as the one you have =)
Reply to N19h7M4r3
mmm... I would just stick to the onboard - you won't notice any difference and you have an i7 which can handle the sound processing and everything else just fine.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
creative blew it in vista drivers for my audigy platinum2 , understandably its an older card but my onboard is decent for most things. I think alot of people had issues with audigy drivers on vista m at least i read enough to decide that creative was less an audiophile than I was :D
Reply to verndewd
Its up to you, since your sound card is a Creative SB X-Fi Platinum 7.1 Channels
it can pretty much cope to your current system and will provide you extra features
that you cannot find on build-in sound cards.
The card's audio processor with CMSS-3D technology is able to
remix your stereo audio into surround sound—even through stereo headphones.
And if you enjoy making music as much as listening to it, this sound card offers precise,
low-latency audio recording capabilities without taxing your CPU. :)
-- If you gonna migrate to Win 7, i think Microsoft decided to provide broad
support on legacy devices including those Sound Blaster's, so you're safe
using it if you're on Win 7. Not sure with Vista since it has many questionable
features particularly on drivers.
Message edited by Rock_n_Rolla on 10-18-2009 at 07:31:04 AM
Reply to Rock_n_Rolla
I used to have a Creative X-fi, and Creative did finally release some drivers for the card to work in Vista. But I never really got over how pissed I was that I could not use any features of the card for so long. When they finally did release some drivers, it did help some, most of the features of the card would finally work. But not all of them. I yanked mine out, gave it to someone, and gave Creative the middle finger up.
You will just have to try both and compare, see what you can and cannot do with the Creative piece of s**t in Windows 7, and make up your own mind. New motherboard though, I am going to say you may do exactly what most people have already done and just forget about add in cards.
Reply to jitpublisher
There are 783 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
