Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Im thinking about upgrading my graphics card and power supply
Forum Graphic & Displays : Graphics Cards - Im thinking about upgrading my graphics card and power supply
its an acer aspire m1300 with everything stock heres the specs: http://www.amazon.com/Acer-M3100-U [...] B000Y9Q3IK
i was thinking abut putting this card and PSU into it but i need to know if its worth it : http://www.newegg.com/Product/Comb [...] mbo.228691
Message edited by thecoke on 08-09-2009 at 04:16:37 AM
Sponsored Links
You don't need to spend 100.00$ on a PSU for that particular computer... Unless you HAVE to go modular....
Antec earthwatts EA500 500W Continuous Power ATX12V v2.0 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817371007
and this :
SAPPHIRE 100253HDMI Radeon HD 4650 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Low Profile Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814102829
The antec EA500 is more than enough for anything you install on that PC...And you have a beefier video card.....
Message edited by OvrClkr on 08-09-2009 at 04:44:38 AM
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
could that card run l4d on med settings smoothly?
Reply to thecoke
- 0 +
* OS: Windows XP, Vista, Vista64
* CPU: 3.0 GHz P4, Dual Core 2.0 or AMD64X2 (or higher)
* RAM: 1 GB for XP / 2GB for Vista
* Disc drive: DVD-ROM Drive
* Hard drive: At least 7.5 GB of free space
* Video: Direct X 9 compatible video card -- Video card must be 128 MB or more and should be a DirectX 9-compatible with support for pixel shader 2.0 (ATI 9600 or high. Or, Nvidia 6600 or higher)
* Sound: Direct X9.0c compatible sound card
My guess is yes... as long as you don't use xAA
And make sure you have enough Ram.....
Message edited by OvrClkr on 08-09-2009 at 05:46:56 AM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Just about everything can run l4d on med setings. it is not that graphicly intense.
But i would get a 4850 or 4770 for the GPU just to future proof.
------------------------------ http://img191.imageshack.us/img191/885/14y1fuqvybiiwayab.gif
Reply to overshocked
- 0 +
umm whats xAA?
Reply to thecoke
http://www.newegg.com/Product/Prod [...] 6814121320
Here is a much better video card. Yet another 9600GSO. 512MBs of ram, DDR3 memory, and 96SP. Costs about the same as that 4650 (with slow DDR2), but $20 cheaper after rebate.
The Antec EA500 is a great PSU, but check around before you buy. $75 is a bit steep.
Edit: OMG, here. http://lmgtfy.com/?q=Anti+aliasing
Message edited by 4745454b on 08-09-2009 at 06:09:34 AM
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
- 0 +
Anti Aliasing....
http://en.wikipedia.org/wiki/Anti-aliasing
Basically if you use it, you will have more detail but it lowers your performance....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
I wouldn't say more detail, that is misleading. AA makes your straight lines look straight(er).
Always a DEMON!
Reply to 4745454b
- 0 +
Whatever.....
He has the link to the full definition, just in case he doesn't understand....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
