I need some help to overclock my e7300 to 3ghz because some of the games i want to play lag if the cpu is below 3ghz. would overclocking to 3ghz fix this?
my pc hardware:
c2d e7300
Asrock 4CoreDual-SATA2 (the board accepts ddr1 and ddr2 with 2gb limit) P2.20 BIOS
1x 2gb stick off ddr2 PC2-6400 (400 MHz) kingston
HD4890 1gb vtx3d
be quiet 530w psu
win 7 32bit ultimate
ive never overclocked before and i wil be getting an athlon 2 x3 (or maybe btter depending on what toms hardware budget cpu says at the time) in a couple of months with new mobo and ram but i just wanted to overclock this until i get it. i cant really afford to do damage to my psu and graphics card so is there any chance overclocking would damage them?
i need step by step instructions as i dont know what im doing plus i heard you need to mess around with the ram also to do it. also would it require wiping my hdd and fresh install of windows?
any help will be appreciated thanks
my pc hardware:
c2d e7300
HD4890 1gb vtx3d
be quiet 530w psu
