Problems setting up port forwarding for Remote Desktop
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I just started playing around with Remote Desktop and I love it.
However, I'm having a problem changing the port that the client uses
to connect.
Here's what I've done. I have a Buffalo WBR-G54 router. I
successfully set up port forwarding so that if I use the Remote
Desktop Client to connect to the router's WAN IP, 123.456.789.1 at
port 3389 it correctly forwards it to 192.168.1.5:3389.
However, I want to change the external port number so I can connect to
123.456.789.1:1234, for example and it will be forwarded to port 3389
on the correct machine.
I can't seem to get this to work. I can use Steve Gibson's Shield's
Up (at www.grc.com) to confirm that port 1234 is open. But when I try
to connect from a client, it doesn't work.
Can anyone help?
thanks,
Peter
11 answers Last reply
More about problems setting port forwarding remote desktop
  1. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    > to connect.
    Change the port on the machine (Remote Desktop Listening Port) and then just
    forward requests on that port on your router to the proper machine.
    (Search Microsoft's site for how to do that and open up that port through
    the Windows Firewall if necessary.)
    <- Shenan ->
    The information is provided "as is", it is suggested you research for
    yourself before you take any advice - you are the one ultimately
    responsible for your actions/problems/solutions. Know what you are
    getting into before you jump in with both feet.
  2. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I'm not sure where you're going wrong.
    I don't know for sure that your unit has this capability--which is
    sometimes referred to as UPnP forwarding. If it does, and the UI is
    unambiguous, it should be working.
    One thought is to check that you are on the latest firmware for your device.
    It probably isn't worth very much to do this just for the "security by
    obscurity" aspect, but it can be useful if you have a small number of
    multiple machines behind the router you want to reach.
    "Peter Kronenberg" <pak@nospam_carouselpuppets.com> wrote in message
    news:osgbn0p1k6g7p7u0s30t9467kl25c7sdu8@4ax.com...
    > to connect.
    > Can anyone help?
    > thanks,
    > Peter
  3. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I have a WBR-G54, although I have not tested using Port Redirection like your trying, only Port
    Forwarding like you said works.... Hmmm...
    Have you tried this telnet test to verify you can get through the router using the new port?
    http://support.microsoft.com/default.aspx?scid=kb;en-us;Q187628
    Have you contacted Buffalo tech support about this to see what they have to say? I understand their
    tech support is very good...
    Otherwise, as "Shenan" mentions changing the listening port on the PC is the work around, if you
    can't get Port Redirection to work and since you verified straight Port Forwarding works...
    If you do change the listening port then make sure you...
    a) reboot the PC after making the registry change and
    b) make the change to the router port forwarding also.
    READ THESE TWO KB ARTICLES FIRST...
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;256986
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;322756
    Change the Remote Desktop listening port and calling procedure...
    http://support.microsoft.com/default.aspx?scid=kb;en-us;Q306759
    http://support.microsoft.com/default.aspx?scid=kb;en-us;Q304304
    Just for information what firmware are you running in the WBR-G54? I currently run the v2.20
    firmware, if that makes a difference.
    Unfortunately I have not tested Port Redirection through the router simply because my current mobile
    client, an iPAQ 5555 PocketPC, does not allow me to change the Terminal Services Client/Remote
    Desktop calling port like a desktop/laptop does... A big limitation...:-(
    Al Jarvi (MS-MVP Windows Networking)
    Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
    The MS-MVP Program - http://mvp.support.microsoft.com
    This posting is provided "AS IS" with no warranties, and confers no rights...
    > to connect.
    > Can anyone help?
    > thanks,
    > Peter
  4. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Well, my router has a section for UPnp, but I don't quite understand
    it. The section called Address Translation is where the Port
    Forwarding is defined. It definitely lets me specify a WAN-side port
    and a Lan-side.
    Although I will potentially do this with more than 1 computer behind
    the router, security by obscurity was part of my reason. Why do you
    say it's not worth it?
    >> to connect.
    >> Can anyone help?
    >> thanks,
    >> Peter
  5. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Thanks, I'll check all that out. I'm running 2.06 of the firmware. I
    didn't know there was a later one.
  6. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I found the v2.20 firmware on the Hong Kong download site...
    http://asia.buffalotech.com/download/index.php?c=hk
    news:e4jcn0d7pc6okiliv7q6jn3l0q1lnhmt65@4ax.com...
    >>their
    >>mobile
  7. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I just checked and the v2.20 firmware is now available on the US download site...
    http://www.buffalotech.com/support/downloads-product.php
    "Sooner Al" <SoonerAl@somewhere.net.invalid> wrote in message
    news:OOGJToptEHA.1720@TK2MSFTNGP14.phx.gbl...
    >>>their
    >>>mobile
  8. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Tried this and surprisingly (or not so), telnet can't get through.
    But how can that be since Shield's Up reports the port as open?
    After I upgrade the firmware, that will be next. I couldn't find any
    place on their website where they say what has changed. I see that
    2.20 just came out a few days ago.
  9. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    It may be simply an issue with "Port Redirection" not working versus "Port Forwarding" which is
    working. Port Redirection may simply be broken in the firmware, whatever version you run.
    I have an issue with not being able to get a PPTP VPN tunnel through the WBR-G54 router, even though
    the Buffalo tech support FAQ claims it can be done. I guess I need to call tech support and see if
    they can provide an answer, although I doubt it...
    As far as release notes are concerned, they are usually rather thin on that... You could contact
    Buffalo tech support about changes... If you do, please post what you find out...
    Beyond that, the router supports WPA-PSK (TKIP) which plays nice with my iPAQ 5555 PocketPC...:-)
    Thanks...
    news:jakcn05luvat2s2qil9lippvvlg3mc5e2b@4ax.com...
    >>their
  10. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I couldn't accurately give you odds about how much safer such a change might
    make you. Certainly it'll avoid someone simply scanning on port 3389, and
    looking for a Terminal Services response. Scanning on other ports takes
    very little more time, though and if someone is really after you in
    particular, and not just out there browsing, I suspect it won't take long
    for them to spot the port.
    There's certainly nothing wrong with making that change--I'd just advise not
    being too sanguine about the amount of additional protection it affords.
    Use strong passwords and log successful and unsuccessful logins.
    So--in the router you've defined the external port as XXXX, and the internal
    port as 3389, and used the private IP of the designated host machine (which
    is still correct?). And on that host machine there is either no firewall,
    or, ideally, one which has port 3389 open?
    When you tested with port 3389 and it worked, were you using this same
    dialogue in the router--i.e. XXXX=3389?
    Are you testing from the same site--i.e. do you know that 1234 is open
    outbound? I hope that you aren't testing from behind the router--this often
    does not work.
    news:mricn01cg51no85gqt6cer2bi8cv8h1vlq@4ax.com...
    > and a Lan-side.
    >>device.
    >>> to connect.
    >>> Can anyone help?
    >>> thanks,
    >>> Peter
  11. This topic has been moved from the section Windows XP to section Storage by Jpishgar
Remote Desktop Port Forwarding Connection Storage
