APPROXIMATE PURCHASE DATE: Tomorrow or ASAP
BUDGET RANGE: $600-$750
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Surfing the web. Possibly other uses such was watching videos/HTPC
PARTS NOT REQUIRED: hard drive, optical drive, keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, slickdeals.net
PARTS PREFERENCES: I would like to choose components around an Intel Core i7 920
OVERCLOCKING: I am willing to overclock, however I have no experience with overclocking. I am comfortable with it, if it is fairly easy and reliable
MONITOR RESOLUTION: unknown
ADDITIONAL COMMENTS: A client of mine wanted to buy a pc from Best Buy for about $600 or less, but accepted my offer to build a computer buying individual components for cheaper than what is available at Best Buy. As per a brief discussion with my client, he wants a device primarily for surfing only one foreign news related website with and the ability to watch videos in a browser environment. This was after he was excited by my build for him, however, I explained to him that I feel this build is too much for such a simple task. He then suggested maybe in the future he will have other use for it. However, perhaps a netbook or nettop would be suitable. His main concern is having a computer system that doesn't lag or isn't slow. His current computers are horrendously slow, even after my optimizing them for best performance. They are rather outdated computers from earlier this decade. I haven't used any netbooks or nettops, but perhaps they may be something I should consider?
My client does not want a netbook or nettop. They want a desktop. Also, after having suggested to them that they could have multiple displays, keyboard and mice connected to the system allowing multiple users to use the system at once, they expressed interest in the idea, however, I am not sure it is a requirement for this build, but instead a potential. My build supports that potential.
I wouldn't suggest getting such a high powered computer just for surfing the web, why not just get a Phenom II x3 710 with a cheap 790gx motherboard and use onboard graphics, 4gb ddr2 800 ram, and stock cooling?
Initially I thought $750 for the build was amazing, however, I guess it isn't? The case is horrid, and the gpu was intentionally minimal since the system won't be used for gaming, graphic/video design or anything similar, simply watching videos. Also, is the cpu cooler necessary?
Because I wasn't confident that the build would be worthy due to a crappy case, and I am unable to spend more, I started another build.
I compared prices to tomshardware cpu benchmarks (AVG, Photoshop, and a couple others) and after hours of analyzation I determined the best value to be AMD Phenom II X3 710 2.6GHz Socket AM3 95W Triple-Core Processor Model HDX710WFGIBOX - Retail.
Even the AMD Phenom II X3 720 seemed to not compare in benchmarks for $20 more.
APPROXIMATE PURCHASE DATE: In a few days/asap
BUDGET RANGE: $500-$750
PREFERRED WEBSITE(S) FOR PARTS: most inexpensive/best value
PARTS PREFERENCES:
