Tom's Hardware > Forum > CPU & Components > Sound Cards > Will a sound card improve microphone SQ?
Forum CPU & Components : Sound Cards - Will a sound card improve microphone SQ?
I'm wanting to plug a microphone into my computer via a 1/4" to 1/8" adapter, but a quick question arose. Will a sound card improve the sound quality, or will the integrated sound be adequate? Thanks :)
Sponsored Links
depending on what you are using it for, just for online chat, use the intagrated, but if you are recording stuff like singing, go with an aftermarket sound card
------------------------------ HP DV1659US Notebook, Core Duo mobile T2450, 2GB DDR2 667 PC2-5300 RAM, DVD Burner, 14.1in Widescreen, GMA945, Windows 7 Ultimate 32 Bit RC 7100, 100GB SATA HDD 20/80, Wireless a/b/g, 3 USB 2.0, 1 Firewire, HP Remote
Reply to furious_cruzer
it also depends on the quality of the microphone, since you have to use a 1/4" to 1/8" convert it is probably higher quality than the integrated will handle so a sound card might improve quality, but try just using the integrated and if that is insufficient then invest in a sound card but the quality of the integrated sound should be sufficient unless you are using your computer as a recording studio.
Reply to hunter315
I'm pretty sure sound cards only output and not input
Message quoted 1 times
Message edited by ubernoobie on 10-19-2009 at 03:06:28 AM
Reply to ubernoobie
Every one I've ever seen has had Line/Mic-In :shrugs:
Thanks for the help everyone. I guess I'll just test it out and see how it goes :)
Reply to Pyroflea
That's correct. My advice, see how the existing sound is before spending!
Reply to mi1ez
Alright, thanks. I've just never actually had a sound card in any of my computers, so I didn't know if there was some absolutely mind-blowing difference in quality or not.
Reply to Pyroflea
i used to have a 7.1 soundblaster card in my old pc, but that was for surround sound purpose when watching dvd's, but like they said, it depends on what your gunna do, good luck
There are 1232 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
