I'm building a new gaming desktop but I can't decide between an i7-920 processor or an i7-950. Here's my system so far:
ram
GSKILL 6GB DDR3 1600
<http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225>
video card
Zotac GeForce GTX285 1GB
<http://www.newegg.com/Product/Product.aspx?Item=N82E16814500096>
processor
Intel Core i7-950 3.06GHz
<http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211>
Intel Core i7-920 2.66GHz
<http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202>
motherboard
EVGA X58
<http://www.newegg.com/Product/Product.aspx?Item=N82E16813188051>
case
Cooler Master Centurion
<http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152>
power supply
SeaSonic M12 600W
<http://www.newegg.com/Product/Product.aspx?Item=N82E16817151030>
hard drive
Hitachi Deskstar 500GB 7200RPM
<http://www.newegg.com/Product/Product.aspx?Item=N82E16822145215>
cd/dvd drive
Samsung DVD+RW
<http://www.newegg.com/Product/Product.aspx?Item=N82E16827151187>
I want to order all this later in a few days. Also, I'm building for the long haul, 4-5 years if possible. i'm planning to upgrade video (and psu) in a few years and add ram, but i'm hoping everything else will go the distance.
I have 3 questions:
1) Is 600W power supply sufficient?
2) What should i be looking at in the way of cooling?
2) should i get an i7-920 or i7-950? They're pretty close in performance, but the 950 costs 2x as much. the 920 is a much better value but i'm wondering if the lower speed will be a problem in a few years. some games already ask for 2GHz+ quadcores (GTA4 for example) so 2.66GHz (vs 3.06 on the 950) doesn't seem to leave a lot of room. budget is not a huge concern - i'd be happy to save $300 but i'll pony up for the 950 if it will save me an upgrade down the road. any advice would be welcome.
also, i'm not planning to overclock since i don't know what i'm doing and don't want to fry my whole system, so i hope whichever processor i pick will be able to last 4-5 yrs at stock settings and still run games on reasonable settings.
What are your thoughts?
any other opinions/comments on my build are also welcome!
ram
video card
processor
motherboard
EVGA X58
case
power supply
SeaSonic M12 600W
hard drive
cd/dvd drive
Samsung DVD+RW
I have 3 questions:
