Yes No
Ads
Tom's Hardware > Forum > Home Theatre > Tivo > HELP: Have a season pass set up for E.L. Raymond, but it T..
Forum Home Theatre : Tivo HELP: Have a season pass set up for E.L. Raymond, but it T..
Archived from groups: alt.video.ptv.tivo (More info?)
I have had this Tivo since Christmas and it has always recorded
Raymond, but this week, skipped it. It DID record Still Standing and
Two and a half Men and CSI Miami as usual. There was not a conflict.
Any suggestions out there??
Thanks,
Ron
Reply to Anonymous
Maybe your Tivo is developing taste.
-Eric
Reply to Anonymous
> Thanks,
> Ron
Was it a repeat by any chance?
Randy S.
Reply to Anonymous
> -Eric
Ok, that's a bit funny ;-). But seriously, I think it's been an
unspoken rule that this group doesn't discuss what shows are *worth*
recording. It could *really* get ugly! Just over American Idol alone!
;-) (Which apparently is much better this season !?)
Randy S.
Reply to Anonymous
- 0 +
>Thanks,
>Ron
Wait for the Comcast developers to fix it.
Sean
Reply to Sean
What does the TiVo give as the reason for not recording it?
Reply to Anonymous
Sean <none> shaped the electrons to say:
Ah, so this will be your new catch phrase.
Too bad it sounds like Comcast is paying TiVo to do all the work,
which kind of makes you look foolish. Again.
-MZ, RHCE #806199299900541, ex-CISSP #3762
<URL:mailto:megazoneatmegazone.org> Gweep, Discordian, Author, Engineer, me.
"A little nonsense now and then, is relished by the wisest men" 508-755-4098
<URL:http://www.megazone.org/> <URL:http://www.eyrie-productions.com/> Eris
Reply to Anonymous
But Comcast developers are apparently too stupid to be counted on to
develop their own product, and Comcast decided to _pay TiVo_ to develop
better software for their boxes...
What part of this don't you understand, Sean?
Lenroc
Reply to Anonymous
"Coyote Ron" <coyoteron@yahoo.com> wrote in message
news:j6le315qfupo5tprlb1r7247bbkme5mek1@4ax.com...
> Thanks,
> Ron
Check your recording options for the ELR Season Pass. It's probably set
to record _only_ new (first-run) episodes. I believe Raymond is currently
airing episodes voted on as fan favs ---by definition, repeats---as a
tribute to the series in this, its final season, and because the cast
contracted to do only a limited number of eps for this final season. (You
can select it in your SP options also if you want TiVo to record both first
run and repeat episodes.)
Also make sure you don't have your options set to "Keep Until I Delete"
while also indicating a maximum number of episodes to maintain. If this is
the case, once your number of episodes recorded reaches the max you've
indicated, TiVo will only resume recording once you delete your recorded
episodes to some number below that maximum---even if there's no conflict.
For your favorite shows you may want to indicate "Keep Until I Delete"
and, for number of eps, "All Episodes." Though this reduces the space
you'll have available on your hard drive until you manually delete, it does
ensure your favorite shows are safeguarded.
Hth.
Wanda
Reply to Anonymous
I had to manually tell mine to record it because it wasn't on the "To
Do" list beforehand. I think it's because it was a "viewer's choice"
episode without a title and episode number, and last week was also
"viewer's choice" so Tivo think it's the same episode. The original
airdate is listed as 2/28/05, so that also adds the issue of Tivo
thinking it had been on in the last 28 days.
Something like that. Anyway, mine wouldn't have worked either if I
hadn't happened to check it a few minutes before. The next 2 weeks
will also be "viewer's choice" so you might want to change your
settings.
I haven't watched it yet, though, so I can't tell you what ep. it is.
p.
Reply to Anonymous
MegaZone (newsREMOVE@THISmegazone.org) wrote in alt.video.ptv.tivo:
s/Again/Still/
Jeff Rife |
| http://www.nabs.net/Cartoons/Rhyme [...] eFinal.jpg
Reply to Anonymous
On Tue, 15 Mar 2005 23:53:41 GMT, Parris <parris@NOinorbitSPAM.com>
>settings.
>p.
Wow...Thanks for the answer p. Sounds like you have the right info
and know what you are talking about!!!
Thanks
Ron
Reply to Anonymous
- 0 +
news:j62f31h3uf66jfbebu5h3vaeuiqgssd5es@4ax.com...
>>settings.
>>p.
> Thanks
> Ron
This is exactly why the 'To Do List" should be checked on occasion or to be
more thorough go through the 'Season Passes' and view upcomming episodes of
each to see what will be recorded. While Tivo is generally great at doing
it's job, It's not perfect. You still need to step in and make sure
everything is as it should be once in a while.
Reply to Kenny
>> Thanks,
>> Ron
> Hth.
> Wanda
WOW!! Thanks Wanda...that was REALLY informative. I really
appreciate the time you took to give me such a detailed answer!!!
Ron
Reply to Anonymous
On Tue, 15 Mar 2005 17:00:33 -0500, "Randy S."
>> -Eric
>Randy S.
Thanks Randy. I totally agree. Sometimes, we just need mindless
dribble to take our minds off the daily "stuff" we deal with.
Ron
Reply to Anonymous
I didn't see a reason...just no show, but think I've got the answer
now. Thanks for replying in2sheep :-)
Ron
Reply to Anonymous
On Tue, 15 Mar 2005 23:28:23 -0600, "Kenny" <spcolorado@animation.com>
>>>settings.
>>>p.
>> Thanks
>> Ron
Sounds like good advice!! Thanks
Reply to Anonymous
and
conflict.
Did you look?
TiVo Central -> Pick Programs to Record -> To Do List -> View Recording
History
Find the episode it didn't record and find out why. This is a good
debugging tool for issues like what you had.
Reply to Anonymous
There are 2159 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 22 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
