Tom's Hardware > Forum > CPU & Components > CPUs > Built new PC, smells like somethings burning ? help
Forum CPU & Components : CPUs - Built new PC, smells like somethings burning ? help
Built my first rig 2 days ago and ever since theres been a light burning smell in my room, the smell of something burning. It is NOT strong but its noticeable. I have downloaded every temperature monitor there is and also checked them through bios and EVERYTHING was perfect, no unusual temperatures. Ive read somewhere that sometimes when you build a new pc it can smell like somethings burning but usually its just the fresh parts releasing heat for the first time is this true ? why the heck is it smelling like somethings burnt if all my temperatures are fine ... someone help me out a bit.
Sponsored Links
This may sound a bit odd, but have you gotten down and actually given any of the specific parts a good wiff?
I would definitely smell the PSU, the GPU, and the CPU....
This may not be the best answer in the world, but tracking down the smell to a single component may help =P
Reply to Kithzaru
It could be the PSU...some PSU makers use cheap paint and when it heats up it kinda stinks....
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
I'd definitely be a little scared to leave that on 24/7. What is your build?
Reply to ominous prime
When i installed a HX520 Corsair into an older system i also got the stench of something burning. I checked and double checked everything, removed the PSU checked it etc. Finally decided it was just flux/paint whatever and reinstalled it. After a few days the smell went away and it was fine.
Reply to dirtmountain
Post the specs on your new build that is making a burning smell as the specs could possibly tell us something.
Reply to jj463rd
My build is a
AMD Phenom II X2 550 BE
4GB RAM
GeForce GTS 250
Windows 7
OCZ StealthXtreme 500W PSU
I ripped off the side of my case and stuck my nose all over all of my components. Nothing smelled like fire, i think i found out what it is. I have an Xclio Nighthawk case that was just released on newegg, the case comes with 4 fans 2 in the front 1 on side and top, when i sniffed the side fan and top fan, they both had the little burning smell so it must be the fans. Ill be replacing them soon but im still keeping an eye on all my temps just incase. they are all fine for now, thanks for the help guys.
Message edited by jrams116 on 10-21-2009 at 05:22:33 AM
Reply to jrams116
Glad nothing's caught fire, always a good thing. Hope the replacement fans get rid of the smell.
I smelled something burning one time. I checked my front intake fan and it was completely burned out. It wasnt moving and it was like 100 degrees to the touch, took like 10 minutes for it to cool down after i took it out.
Reply to bige420
Glad it wasn't something major!
Reply to Kithzaru
There are 690 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
