I will be buying a system with the case being the cooler master haf 912. I will have a power hungry graphics card, being the gtx 580. I know already that I will be getting rather hot, and I need to figure out the best AIR cooling solution to keep the whole system cool. It has to be really effective.
I have been doing a lot of research and am still rather confused.
I have read countless topics on different forums, and everyone has their own OPINION.
Some say, that I should only have intake in the front, and have no fans that take out the air. I think that is wrong..
I know the case comes with two 120mm fans. They recommend having one in the front and one in the back. There is also a spot for a fan at the top, and on the side as well.
Now here are the questions :
Where should I put the stock fans that come with the case?
Should I buy any extra fans?
If I buy any fans, what sizes should they be?
Do I need fans for the side and top?
If yes, the top should be intake or exhaust?
Should the side be intake or exhaust? I think it should be an intake, for the gpu is close to the side. ( I could be wrong)
If I need to buy any other case fans, how many?
Can the stock fans keep my system cool?
If I need anymore fans:
I do not need any fans with led, and the color does not matter either.
I need the fans to cool well, but they also have to be rather quiet. I don't want it to sound like a jet is taking off in my room.
They can produce some noise, but seriously minimal.
Hopefully, I can come up with a strong cooling solution!
