Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 4670 power requirement
Forum Graphic & Displays : Graphics Cards - 4670 power requirement
i've done quite a bit of surfing the web in research, and i've read a good number of posts saying a 4670 is fine for a 300w power supply (mine is 300w that came with the computer, single 12v rail at 19a)- i just thought i'd ask the question myself- should i risk installing it?
I got a athlonx2 2.5, 1 cd/dvd drive, 320gb hard drive 3gb ram- and the computer's still on warranty, if that has any bearing.
i'm planning on getting a new psu in the near future, i just really want to start gaming (first time really playing on a pc).
thanks
Sponsored Links
I have seen the 4670 run on 400w PSU's but a 300 watt is kinda pushing it....
If you can shell out 39.99$ then you can get a name brand 370W PSU and leave you worries behind....
PC Power & Cooling Silencer PPCS370X 370W ATX12V 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817703018
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
19a on the 12v is enough for the 4670, its enough for the 9600GT also
------------------------------ Recipient of multi-best answer awards and $3 power ball winner!!
Reply to ct1615
I wouldn't try it. People claim you can, but not all PSU's are created equal. Upgrade to a 400W if you want to ensure smooth operation.
Reply to Hindesite
A generic 400w psu is equivelent to a quality 250w psu. Dont buy based on stated wattage alone.
A quality 400w+ is what you need
Reply to zipzoomflyhigh
i have a generic 220w psu and it can still run that card.
but i will not suggest it .
you may risk your card like i am risking it.
i have very slow and old pc DDR1 512 mb ram and amd sempron 2800+ so it works.
but its risky to run
Reply to iplaygames
That card needs less than 5A running flat out. You should be fine, even if that PSU has to be de-rated to 75% of capacity.
Ovrclker has a point, you don't need to spend a lot to get a good PSU. The one he linked or an Antec Earthwatts 380 would both be good, long term choices.
Reply to jtt283
From my own experience, a ATi Radeon9800XT made a chieftec powersupply rated at 400W stopped working correctly after 6 months.
Get yourself a high quality 650W powersupply (like Corsair for example) and you will be alright for the coming 10 years to come, if you can afford it. They had a 5 year warranty on them the last time I checked.
Reply to khelben1979
http://www.newegg.com/Product/Prod [...] 6817182017
this one was 39.00 last week..I bought it and love it and powers my 4850 without issues
Reply to fivepointnine
It probably should work yeh, altho definatly have to agree do you really want to risk it. Just buy a antec earthwatt 380, they arent that expensive rly.
And 650 watt is just extreme overkill for a 4670, he has a reason for getting a 4670 rather then a 4870. its called budget
Reply to ill b ben
anyone know if azza makes solid psu's?
Reply to levesque
Neither are good.
If you want a good inexpensive brand then go with Fortron Source (FSP) or Antec.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
It should be fine to be honest. You could spend more money on a new PSU if you can afford it but I wouldn't be that stressed about it. The 12v rail suits the card just fine and there shouldn't any serious issue as the the 4670 is a great low power solution.
Reply to Jaysin
There are 1112 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
