Hi there, hi have a Samsung TSST Corp CDDVDW SH-S223C optical drive which is a CD/DVD drive with SATA interface. I have it for near half a year and I've had no problems with it so far. I mainly use it to read cds as I've been absent from pc gaming for a while and so I haven't used dvds on it. A couple of weeks ago I bought a music dvd, a triple dvd edition, and something wild happened. The first dvd wouldn't start playing as it wasn't able to access the disc, the drive kept spinning fast then halting and doing that sound when its skipping read on a cd (like tssut , tssut, tssut). Funny thing is that the other two dvds would play just fine. I've tried all dvds on two other computers and two tv dvd systems, and they all worked fine on each and every one of them. So the problem was with my drive! I updated the firmware and when I then put the first dvd it starts accessing again but this time it reads, it's just that it takes something like two minutes to get to the dvd root menu. After being at the root menu it plays just fine but every time that I put it in or restart the dvd the same thing happens. Also when the drive tries to access the dvd the system becomes a bit unresponsive.
So I've thought that it would be a one time wonder with this problem and that it could be some minor deal. Last night I bought C&C3 Deluxe (Tiberiuum Wars + Kane's Wrath) and the same thing happened again. The TW dvd wouldn't access but the KW would! I've spent a few hours googling for solutions and tried a lot of things, don't ask me to repeat everything that I've done because I can't remember all of them. The TW dvd wouldn't even load the splash screen for the dvd autorun, it would give a black window with an error message. A bit later on I've started testing my other original games to see if any other dvd would do the same but they didn't, they all worked fine. So after trying half a dozen dvds I've put on TW again and this time it loaded the splash and started installing. But then at around 75% it started trying to access the dvd again and halted the copy of new files, it just stopped there. It also started doing this: the drive starts to spin real fast trying to access the dvd, then it suddenly slows down and starts doing a chipping noise, then it repeats on and on.
I'm going a little crazy with this problem and I wanted to know if there's any known similar issues, any workaround or any simple solution that I haven't found. I think I might have to get it to guarantee and get a new drive but I wanted to exhaust my options before doing that.
Any help would be good.
