So, I opened a thread a week or so ago about the placement of my aftermarket cooler and additional fans to get the best cooling performance, and got a bit of a range of responses.
The cooler arrives today, and over the next week or so I plan to run a few tests on different configurations, to see which is best for different goals:
1) CPU cooling
2) Overall System cooling
I will have access to a temp probe/monitor to get average ambient temp over the duration of the test to account for differences. I plan to use Prim95 for CPU and EVGA OC Scanner for the GPU.
If there is better test programs or additional temp logging systems, I would appreciate it if you could suggest any. Also, if you can think of other test configurations than what follows, suggestions would also be welcome and appreciated.
1) Control (Stock cooler, side exhaust sealed)
2) Control Side (Stock cooler, fan on side exhaust)
3) Aftermarket/vertical/single fan (side exhaust sealed)
4) Aftermarket/vertical/single fan (with side exhaust fan)
5) Aftermarket/horizontal/push-pull (side exhaust sealed)
6) Aftermarket/horizontal/single fan (side exhaust sealed)
7) Aftermarket/horizontal/single fan (with side exhaust fan)
Thinking I may eliminate 3 & 4 just because I think that will have minimal difference, and I'd also like to save on the Arctic Silver since I'm edging on poor.
Setup being tested on:
Mobo: MSI P67A-GD53 (B3)
CPU: Intel i5-2500k
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) DDR3 1600
GPU: EVGA GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5
PSU: CORSAIR Enthusiast Series TX850 V2
HDD: SAMSUNG Spinpoint F3 1TB 7200 RPM 32MB Cache
Case: Antec 300 Illusion
Cooler: COOLER MASTER Hyper 212 Plus
Thermal Compound: Arctic Silver 5
Extra Fan: Scythe DFS123812-3000 "ULTRA KAZE"
1) CPU cooling
CPU: Intel i5-2500k
