Tom's Hardware > Forum > Homebuilt Systems > New System Build > New Builder about to purchace parts - Need quick review!
Forum Homebuilt Systems : New System Build - New Builder about to purchace parts - Need quick review!
Hey everyone,
My name is Zach, and this will be my second topical post here on the forums. First let me say thank you to everyone who helped me on my previous thread, as without your help i would be both less knowledgable and less confident in my ability to build a computer.
Origionally I had the AMD Phenom II 940 BE, but saw that by playing with the placement of combos from newegg, I could get the 955 BE for only $5 more, so I jumped on the oppertunity.
So here it is, version 5 - hopefully the final one - of my budget gaming computer. My monitor displays 19x12. I plan to overclock, so if anyone could reccomend a heatsink (? terminology), it would be much appreciated... the cheaper the better if ya catch my drift. I already have a monitor, mouse, keyboard, OS, speakers... if I am missing anything, let me know
Thanks in advance community, all comments are both welcome and appreciated!!
Zach
CPU and Motherboard = 260
http://www.newegg.com/Product/Comb [...] mbo.211664
ASUS M4A78-E AM2+/AM3 AMD 790GX HDMI ATX AMD Motherboard - Retail
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
HD, Case, PSU = 135
http://www.newegg.com/Product/Comb [...] mbo.206878
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
hec Prime Black 0.8mm SECC Steel ATX Mid Tower Black Computer Case With 585W Power Supply - Retail
Memory = 52
http://www.newegg.com/Product/Prod [...] 6820231166
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK – Retail
GPU = 200
http://www.newegg.com/Product/Prod [...] 6814102830
SAPPHIRE 100269SR Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card – Retail
Dvd Drive = 30
http://www.newegg.com/Product/Prod [...] 6827151188
SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support - OEM
Sponsored Links
Well from reading post and all i would have to say NO on that PSU go with a name brand like ( Corsair ) a 550W would do for that setup.
And with a AMD build i would go with DDR3 a AM3 setup Maybe this MOBO http://www.newegg.com/Product/Prod [...] 6813128378 With some DDR3 memory
If you plan to OC run a few HDD and maybe Xfire latter a would say go with a 750W or 850W corsair
Give sometime to let others give there 2 cents GL m8
Message edited by niklas_13 on 07-23-2009 at 04:32:32 AM
Reply to niklas_13
Guys, thanks for the quick response.
While looking at the items you all reccomended, I thought of something... will the motherboard I have now support crossfire in the future.
The way I was looking at things was that in a while, when 4890s become cheaper I would buy a second and run the thing in crossfire. When I went to the motherboards page I didnt see anything saying that it would or would not support crossfire, thus my concern!
On a seperate train of thought, for now I think i will stick with the PSU that comes with the case, as its powerful enough to run all the things I want to have hooked up, and cuts my cost by a lot.
Thanks for your comments, keep them coming! Ill be making all the purchaces this weekend!
Reply to zachtraps
The PSU that comes with that case is a cheap generic that, at best, is overrated (may not be good for more than 75% of its label).
http://www.corsair.com/cinema/movie.aspx?id=622747
(worth a chuckle every time I see it)
...and at worst, may have waveforms that are out of spec, with excessive ripple and noise that may be destructive to attached equipment. Choose a quality PSU, such as Antec, Corsair, PC Power & Cooling, Seasonic, or Enermax.
Reply to jtt283
Yes, your motherboard will be able to run 2 x 4890 in Crossfire. However, the generic PSU included with the case will likely be unable to handle the power requirements of the two cards. The PSU is not a good place to cut costs - go with a reliable brand.
Reply to hecto
Dude, you had all of this answered on your other post. Including the warnings about the crap PSUs. Why post the same junk when the advice has already been given?
And why post twice if you're not going to take our advice anyway?
------------------------------ Phenom II X4 940 @ 3.4
GIGABYTE GA-MA790X-UD4P
2X2GB/ G.Skill PI Black PC6400
HD4770 XFire
Reply to AMDThunder
Thank you all for the comments concerning the power supply
@ AMDThunder: While I did have another post concerning my proposed build for computer, I had always chosen to purchace the PSU seperately (I think) and if i remember correctly, this is the first time i post anyhing about a case that comes with a PSU. It has been the advice of the community that has turned this from a 600 dollar build using last generations parts to a roughly 650 build that will prove to be much more effective. I was unaware that a PSU that comes with a case is ranked as lowly as one with a generic and unknown brand name, and now with this knowledge, i will make moves to rectify the mistake.
To all, thank you so much for helping me move forward and i look forward to reading other opinions as the day passes
Zach
Reply to zachtraps
There are 998 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
