This is a strange one, and I have done everything I can think of. And apologies in advance if I include too many details. Just thought that my various attempts to resolve this might shed some light on the problem.
I previously built a HTPC that was very stable.
Gigabyte GA-945GCM-S2C
Intel E4500
2 GB (2x1GB) DDR2 667 Kingston RAM
SAPPHIRE Radeon HD 3850
Vista Ultimate 32bit.
Again, for two years, no complaints. After picking up a PS3 I really wasn't using this anymore so decided to upgrade to Win 7 x86, bump the RAM to 4GB and re-purpose as secondary work PC.
Before I upgraded the OS and before I swapped cases, I upgraded the RAM just to confirm that it would still post (call me paranoid...). This particular board only has two RAM slots, so I had to replace the two 1 gig sticks with two 2 gig sticks. Same brand (Kingston), same voltage (1.8), certified to work with this MB as per Gigabyte's website. Anyway, I swapped them out and all was good. Motherboard posted fine and recognized all 4 gigs of RAM, as did Vista – actually 3.25 gigs, but I expected that given the 32 bit limitations. Then, I upgraded the OS via a clean install, leaving the new RAM in place. Again, all was fine.
I transferred everything to the new case, only removing/unplugging what was absolutely necessary -- left CPU, heatsink and memory in place. Took all the normal anti-static precautions, etc. etc. Reinstalled everything in new case and powered on.
Nothing. Would not post. All fans (heatsink, video card, case) turned on, DVD drive worked, but could not get it to post. Tried everything I could think of, including removing all hardware that wasn’t absolutely necessary, re-seating memory, rechecking all connections, even removing front case header connections just in case they were causing a short. Still nothing. At this point it was late so I gave up for the night, figuring I had fried something during the case switch. I turned off the PSU and unplugged it.
Next morning, I decided to revert to old RAM to see what would happen. This time, it booted. Obviously very happy that it did, since it meant that the MB was OK. But still… weird. I finished doing some tweaks, installing software, reconnected all hardware and other case connections and restarted several times. No problems.
Tried installing new RAM again. Didn’t post. Tried different RAM (2 GB Crucial DDR2 800 sticks from home PC) that I know are good. Didn’t post (and when I reinstalled them in my home PC, they were recognized as before, so I don’t think I am killing these things when I’m installing/reinstalling – plus, the original sticks of 1 GB Kingston RAM from the HTPB work fine).
Gave up and reinstalled the original 1 GB sticks. STILL won’t post. Once again, unplug AC from PSU, leave overnight. Next morning, boots fine, and has for the past several days.
I'm going crazy trying to figure out what is going on here. I know that the easiest solution would be to leave well enough alone and stick with the 2 GB of RAM I have running now. But it WAS working with 4 GB at one point (and on two different OS’s).
What I have not done (yet) is update the BIOS. Everything worked fine at one point using the current BIOS, so I don’t think that's the problem. I guess I am just wondering if anyone has any thoughts or suggestions before I go down that road. Is there something else I'm not thinking of? Maybe clearing the CMOS?
Thanks and apologies again for the length of this post -- hope I didn't put anyone to sleep with this!
Intel E4500
