Archived from groups: comp.sys.laptops (More info?)
Hi,
I want to replace the CMOS battery in my 770E. The problem is, I don't
know where it's located. Can someone tell me how to locate it, or
better yet, let me know where I can download a diagram, or illustration
from the web.
Thanks!!
Keyto wrote:
> Hi,
> from the web.
> Thanks!!
Turn it over, remove the large cover in the middle. Those are your memory
sticks. Next to them is a 3v coin battery. Push inward slightly(you see the
little fingers) and lift up the edge of the battery. Panasonic number 2025,
3volt.
TJ
The beatings will continue until morale improves.
In article <4091CC60.3189FC1D@cableaz.com>, Dec7.1941@cableaz.com
says...
> Keyto wrote:
> > Hi,
> > from the web.
> > Thanks!!
> 3volt.
> TJ
Thank You!!
Thanks for the help! I just did my Thinkpad T23 in 10 minutes, the cmos battery was under the usual battery. It cost me $2.74 INCLUDING a roll of electrical tape :> )
Rich
