PLEASE HELP! Cannot Logon, need to return to Restore Point
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I somehow changed the logon information so that I cannot log on. (I was
trying to set an office laptop to be able to log into my home workgroup, and
now neither the work nor the home login info will work.)
I first created a System Restore Point, thinking that if I messed things up
(which I did!), I'd be able to get back to where things were. The machine
has WinXP Pro, and was originally set up at my wife's office (by a guy who
won't be available for days).
What I failed to consider is that, having unsuccessfully tried to make
changes to the username, and from Domain to Workgroup logon, etc, I now
cannot get past "Ctrl Alt Del to Logon" -- so, I am unable even to get to
the Win XP System Restore program!!
I'd be thrilled just to get back to the Restore Point I created before I
began messing with the logon. Can I somehow get to it during startup?
Please, any help would be GREATLY appreciated!
3 answers Last reply
More about please help logon return restore point
  1. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    > was trying to set an office laptop to be able to log into my home
    > workgroup, and now neither the work nor the home login info will
    > work.)
    > things up (which I did!), I'd be able to get back to where things
    > were. The machine has WinXP Pro, and was originally set up at my
    > wife's office (by a guy who won't be available for days).
    > now cannot get past "Ctrl Alt Del to Logon" -- so, I am unable even
    > to get to the Win XP System Restore program!!
    > before I began messing with the logon. Can I somehow get to it during
    > startup?
    First - understand that a System Restore will not help you with YOUR
    settings or YOUR files. It is to restore system files only.
    Also, you shouldn't need to change anything to use the DOMAIN laptop in your
    home WORKGROUP.. You should just have to know your normal logon for the
    domain (unless they turned off caching) and then your usename/password for
    file sharing on ytour home network. You MAY have to know the IPs of the
    machines in your home network as well.
    You may be able to hack the password to the administrators account.. Change
    it to somehting you know - but being a work computer - I hesitate to
    assist - as it shouldn't have gotten this far in the first place. heh
    <- Shenan ->
    The information is provided "as is", with no guarantees of
    completeness, accuracy or timeliness, and without warranties of any
    kind, express or implied. In other words, read up before you take any
    advice - you are the one ultimately responsible for your actions.
  2. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    Thanks, Shenan. At this point it seems I'm locked-out, apart from other
    reasons, from too many unsuccessful attempts. I'll wait for the admin to get
    back from vacation.
    Thanks again.
  3. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    Try booting to Safe Mode, if you can access Safe Mode, you should be able to
    get to System Restore. Boot the system, start tapping F8, when the menu
    appears, select Safe Mode and Press Enter.
    Michael Solomon MS-MVP
    Windows Shell/User
    Backup is a PC User's Best Friend
    DTS-L.Org: http://www.dts-l.org/
    "Ted Kerin" <res00psu@gte.net> wrote in message
    news:LXFJc.11663$kK.8932@newsread3.news.atl.earthlink.net...
    > and
    > up
Configuration Windows XP
