Specifications:
Motheroard - ASROCK P45XE
CPU - Intel Core 2 Duo E8400 / 3.0 GHz / 1333 Mhz / 6 MB Cache
Memory - 4 GB G. Skill (2 x 2 GB) DDR2 1066 (PC2 8500)
Graphics - Nvidia GTX 260 / 896 MB
OS - No OS installed yet
Hard Drive - Western Digital Caviar Blue 500 GB / 7200 RPM
Power Supply - OCZ ModXStream Pro 600 W
Case - NZXT Alpha
So I'm building a new system using the core components mentioned above. The problem is, when I turn on the power, it's seems like it's not booting up correctly and has no power. The fans (CPU, Power Supply, Case fans) would just run for a second and dies. No signs of power going through the entire system. I have pretty much plugged in everything and verified all connections. I even cleared the CMOS jumper just in case that was the problem. I jump started the power supply already and it's working by itself. I'm out of options already and I'm really getting frustrated with this.
PLEASE HELP ME...
Case - NZXT Alpha
PLEASE HELP ME...
