So I am no stranger to overclocking my 1090T I just have a few questions left for anyone willing to answer them.
First of all I have no problem getting 3.8GHz stable on my processor. That was pretty easy and temps stay under 55C under full load. That was all done with just the multiplier and some voltage tweaks. 4GHz seems to be a bit too much for my cooling solution as I need at least 1.475V to get there and my cooler just doesn't seem to cut it with the temps going over 62C and pushing 65C in many cases of running Prime95.
So my question is about overclocking with the multiplier vs. the bus speed. I am about ready to try and methodically work through some bus speed hikes to see if I can find a higher stable clock using more of a combination of bus speed and multi. Yes I do know about all of the other system components that need to be kept track of as the bus speed goes up.
The other question is can anyone tell me if they have benched multi increases vs bus speed increases. Will the latter truly create a noticeable difference when the processor speed is comparable?
I am really looking for some answers with some experience behind them. And if you need the specs they are in my sig.
