Hello,
Sorry if this has been answered elsewhere. I saw similar questions in the Search Forms, but they seemed to apply to a slightly different POST issue.
System specs:
Asus P6T
I7 920
6gb DDR3 Kingston 1333 value ram
Corsair 1000 HX
ATI 5770
CM HAF 932
The Situation:
After cleaning and reapplying thermal paste and reinstalling a Cooler Master v8 last week, my P6T refused to power up. Power was recognized by the onboard power button, but the v8 fan would spin for a ½ second before stopping.
I went through a number of the troubleshooting tips on the Boot Error sticky guide, and even had a Tech at Fry’s Electronics look at the cpu, memory, and mb. Their diagnostics cleared found no problems with the cpu and memory, but the mb failed on them too.
After trying a last ditch effort to avoid buying a new mb, while the mb was on a long piece of cardboard, I tried powering it on without the cpu… somehow the stock hs fan (since it's easier to remove) and board came to life. The problem is that the second I locked the cpu socket, the mb went back to its’ whirl-and-stop action.
If I do not lock the socket but put the stock hs on top of the cpu, I am able to get the board to power up successfully… no monitor confirmations of POSTing activity or speaker sounds (the little board speaker plug that Asus gives you with the mb)...
I know that the monitor is good because I used it on Tuesday to fix a co-worker’s pc, and the psu and video cards (tried different ones) should be good for the same reason.
Per chance, does anyone have a rough idea of how to fix this? Is there any way to loosen the cpu socket clamp, or some way to confirm that it POSTs and display data on the monitor? It doesn’t look like any pins are bent or out of place on the cpu or mb. All of the connections (with the exception of the cpu socket bar) are in pretty secure. The CPU sounds like it's working; I just can't see what its' working on.
Thank you in advance,
Conn
System specs:
Asus P6T
I7 920
Corsair 1000 HX
ATI 5770
CM HAF 932
The Situation:
Conn
