Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Card to USB?
Sound Card to USB?
Forum CPU & Components : Sound Cards - Sound Card to USB?
Hello
How could I use a sound card with my macbook if it doesn't has the SD port? can I get some adaptor to use a sound card with a USB port?
Omar
Sponsored Links
They do make USB powered Sound cards. Whats wrong with the one in your macbook and or what are you trying to do?
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
Your MacBook has a built in audio codec, any specific reason you need an external one?
Also, see newegg's USB Soundcard section.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
Hi thank you for your response. What I'm trying to do is to do home recording with my macbook, I already have the computer I know this one probably won't be enough engine for my purposes, my idea is to get apogee duet, logic pro, install the a sound card to my macbook, and get monitor speakers, I could get a macbook pro later but not now. Do you think my macbook is not a good one to do the job? Macbooks dont have SD port.That's the reason I want to know how I could plug a sound card to the USB port.
I'm going to be recording rock songs, I mean getting the sound from microphones, what;s your recommendation if I do want good recording quality sound?
Omar
Reply to ombor10
The sound card I have in mind is the UAD-2 solo/laptop, am I in the right track?
Omar
Reply to ombor10
There are 1163 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
