Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Emachine t3656 power supply question.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Emachine t3656 power supply question.
I haven't been able to find a replacement for it. I keep finding replacement that go up to the t3638 but skips and up to the t3828. Do you know of any location that has replacement for this model? The power supply that is in it is the lite on ps-5251-7.
Thanks
Sponsored Links
I would remove your old ps first and compare it to some photos at newegg. You may be able to use any atx ps; I recommend antec or ocz for value and quality.
Reply to o1die
There are 1311 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
