Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Can I build my system w/o a cd/dvd drive ?
Forum Homebuilt Systems : General Homebuilt - Can I build my system w/o a cd/dvd drive ?
I hope I finally have enough hardware to get started . Antec 300,psu,gigabyte G31,E5200,2GB ddr2 800 Gskill,19" lcd,keyboard,mouse,used sata 250GB hard drive,used sapphire 4650 . However , no cd/dvd drive or burner .
I have an old HP P4,1GB ram,ide cd/dvd,40 GB hd and the 250 GB hd . I recently downloaded win 7 RC and plan to use this OS for new build . Since the 250 hd is accessible thru the HP , I would like to format it and create several partitions . I was hoping to boot and install win 7 from a partition . Is this possible ? secondly , how about mobo or video card install cd ? Can I create them in the partition also ?
Thank you .
Sponsored Links
Nevermind , I went today and bought a dvd burner . Thanks anyway .
Reply to just4today
Hah yeah I was about to say that it is not possible as far as I know because there is currently no way to install an OS from the internet. That, however, will soon change.
As you found out though, a good quality DVD burner can be had for $25, so go ahead and put one in, unless your budget is so tight you can't even afford that.
There is also the cost of the media, but that's pretty cheap too.
Reply to Marcus52
There are 728 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
