APPROXIMATE PURCHASE DATE: Next few weeks - Mid August BUDGET RANGE: 1400- 1800 (u.s)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: General use , gaming
PARTS NOT REQUIRED: None
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: Just good quality
OVERCLOCKING: No * but may try in future
MONITOR RESOLUTION: 22 inch.. at least 1680
ADDITIONAL COMMENTS: Just trying to build a nice system to do my programming projects for college and play a few games. Warcraft and Lotro is about the extent of the games I play but I would like to have a system that I could play better games if I decided to.
First and foremost, thank you for taking the time to help me with my situation. Any and all comments are greatly appreciated.
The main questions I have are:
1: Are the components I chose compatible with each other and if so is the any items that may create a bottleneck?
2: If I have went overboard with an item with feature I may not need, can you recommend a less expensive alternative of the same or better quality?
3: Am I going to pull my hair out trying to get this thing up and running, lol.
My only experience with systems is changing out common parts: i.e memory, hard disks, audio and vid cards, etc.
I know a little about bios settings but have never tried to OC anything.
So far this is my current build.
AMD Phenom II X4 940 Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Black Edition Processor - Retail
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard - Retail
SAPPHIRE 100269SR Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3P1600LV6GK - Retail
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Acer X233Hbid Black 23" 5ms HDMI Full 1080P Widescreen LCD Monitor 300 cd/m2 40000:1 (ACM) - Retail
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support - OEM
Microsoft Windows Vista Ultimate SP1 64-bit for System Builders w/ Tech Guarantee - OEM
Arctic Silver 5 Thermal Compound - OEM
Scythe SCKTN-3000 92mm Sleeve "KATANA3" 3Heat Pipes CPU Cooler - Retail
Rosewill RTK-045 45 Piece Premium Computer Tool Kit - Retail
Current costs...roughly 1550-1600 without shipping.
Thanks,
William
