[Solved] Corsair HX 1000W Help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - [Solved] Corsair HX 1000W Help
Best answer from DellUser1.
I'm building my own computer and the peices are arriving one at a time. Right now i have the Cooler Master ATCS 840 case and the Corsair HX 1000W PSU. I was really excited so I put the PSU into the 840 and used a modular connector to attach a 4 pin connector. To my simay and horror when I flicked the on switch on the PSU nothing happened. No Fan, No noise from the PSU. Absolutely Nothing. This is sort of freaking me out and I really want to know what's wrong so if it is defective i can maybe return it. Also could it be from not having a motherboard and cpu? PLEASE PLEASE help. and Thanks in advance.
In order to jump start the psu you need to; leave it unplugged with the switch off, put a load on it ( hook up a fan or 2 ), then, on the 20/24 pin main connector, jump the green ( power on ) wire with one of the black grounds ( I use a bent paper clip ), then plug in the psu and turn on the switch ( make sure not to touch the paper clip :o ).
Sponsored Links
Best answer
Reply to DellUser1
^5 +1 what Delluser1 said.
Normally the power supply has to be plugged into the motherboard for the power supply to start up. The paper clip test fools the psu into thinking it is plugged in. Here's is a link to a web page that has two photos showing the paper clip trick:
http://www.broadbandreports.com/fo [...] at#6764627
Scroll down the page to see the two photos.
Reply to JohnnyLucky
Sweet! Thanks guys, I was so worried that I got a lemon or something.
Edit. Tried this and it worked beutifully. A way to solve the accidental shockng of yourself from touching the paper clip is by using an insulated one, just strip of the insulation at the tips and plug those in.
Message edited by Candyviper on 10-23-2009 at 05:17:33 AM
Reply to Candyviper
The signalling voltage on the paper clip is extrememly low. I wouldn't suggest licking it or standing in the shower with it but it won't shock you.
------------------------------ Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
ROFLMAO! :)
Standing in the shower with it? Hm...extreme liquid cooling...cool the components...and yourself :lol:
Reply to jcknouse
I was curious ...
I just happen to have a breadboarded E5200 system powered by an Antec 650 (XMS, my gaming machine uses a TX750 :)). Got out my DMM and measured 5.02 volts (green wire) to ground. When grounded, the dmm read 22 ma. I was a little surprised the current was that high.
Reply to jsc
Well I don't think I will be taking a shower with my PSU but you never know. So if i do I'll try to remember
Reply to Candyviper
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > [Solved] Corsair HX 1000W Help
There are 905 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
