Hello every one, I was wondering, will I be able to put a Bus speed of Higher the 333.3mhz on my CPU if the DRAM frenquency of my memory is 333.3mhz. Or does the frequency of my ram folow the bus speed ?
Thanks for your reply, My MOBO is a Gigabyte G41M-ES2H, 2X2gb DDR2 Samsung M3 78T5663QZ3-CE6, intel core 2 quad Q9300 2.5ghz. And I think thats all I need for my OC infos
