Rate my new system build I'm thinking about (955BE)
Little bit of info:
Building another system to primarily handle gaming, looking to max out performance but keep the budget reasonable. I am using two monitors at 1920x1200 resolution.
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131363
2x in Raid 0
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
2x (8gb total)
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3P1600EB4GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227286
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
2x in Crossfire
XFX HD-489A-ZDEC Radeon HD 4890 Xtreme 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150360
OR
2x in SLI
EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130475
My questions are. What is the better route for video cards in your opinions. Also... am I really losing anything building the 955 for gaming vs an i7 920 setup? How about a Phenom 945 since it seems like the 955 inventory is out at most places?
8 answers Last reply
More about rate system build thinking 955be
  1. 1) that mobo can't do SLI, only crossfire.
    2) 8GB of ram SLOWS gaming.
    3) getting dual cards at that level is pointless at this time as the 5870 comes out in September and since it will only cost around $250, why waste $200 on a soon to be obsolete card.?
    4) since you want max gaming performance for the money, it's best to stick with the 955 BE over the i7 920, unless you have a microcenter near you, then get the $200 i7 920 and a $170 mobo off Newegg and you've equalled out the prices somewhat.
    5) the reason why the 955 is hard to get is because the 965 is coming out soon, probably in September with the 5870 and possibly the 8xx chipset.
  2. too much ram , 4 is enough .
    The game wont use more system ram , than the ram thats on the gfx cards
    4 gig is plenty
    RAID zero is not much use to a gamer either . It will not boost anything except shorten loading times by a few seconds , and in online gaming where the limit is net bandwidth RAID 0 will do nothing but double your chances of catastrophic failure and losing your data .
  3. I appreciate your response. I guess my main question is, since you said get the i7 if I can get it for the microcenter price. What is the i7 giving me though for gaming that the 955 BE isn't?
    That's what I get for posting at 4am... I like to dual boot into linux as well, and ATI cards seem to be finicky in that environment from my past experience. Is there a decent SLI AMD board out there yet for the AM3 socket that also supports DDR3? Not lookin to do a hybrid AM2/AM2+/AM3 board that only does DDR2. Or if I'm in a crossroads and want to run NVidia over ATI, I should just shell out the extra coin and go i7?
  4. ^ the i7 has a higher IPC and better overclocking potential (meaning that the i7 will take longer to become a bottleneck to a graphics card.)
    it also has double the threads ( so each thread handle's an instruction, and there are two threads assigned to a core in the i7, the 955 doesn't have this however) which makes multitasking, and will make future gaming, a lot faster.
    No there isn't a decent SLI AMD board.
  5. expected release date of the PhenomII x4 965 BE is August 13th
    http://www.xbitlabs.com/news/cpu/display/20090710144950_AMD_to_Speed_Up_Phenom_X4_Release_Athlon_II_X4_in_August.html
    No SLI AM3 socket motherboards, but there are several AM3/AM2+/AM2 SLI or AM2+/AM2 SLI boards available.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131383
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200022%20107192495%201071936149&name=NVIDIA%20nForce%20780a%20SLI
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131323
    Some of the P55 Intel boards will come with both SLI and crossfire available just like the X58 boards.
  6. I guess my next question is... good sli/crossfire board for an i7?
  7. ^ most have SLI/Crossfire, I suppose the ASUS P6T is the cheapest if you want a better brand, or the Asrock X58 Extreme if you want to save some $.
  8. go i920 do
    x58-ud3r
    6gb of ddr3
    4890 1gb
    Raid 0 is faster in windows, for unraring,etc
New Build Systems Product
