Hi
I really need some advice, if I may, as while I am very interested in PCs and gaming, I am not a hardcore enthusiast.
I would like to have an extreme gaming PC built but, unfortunately, I don't know enough to be able to fully spec it out, and I will need a company to build it for me.
My budget is up to US$10,000, but I would be more comfortable at around 5K or 6K, which hopefully should allow for the best components. Last time I did a project like this it was some time ago (2003) and I used the nVentiv freezer cooling option on a chipset that was many generations ago.
I am after the very best components, but a stable system, as I don't want to have to repair it all the time. Looking for a 4.6 OC on the processor and a decent OC on the 4 GPU video card set up (2x GeForce GTX 590 3072MB Graphics Card with waterblock cooling from EK or Danger Den).
I was thinking:
1. Case:The Lian Li PC-343B with turnkey liquid cooling installed as shown here: http://www.frozencpu.com/products/6466/cst-628/Custom_Lian_Li_PC-343B_Full_Liquid_Cooling_Ready_Cube_Case_-_Black.html
2. MOBO: Asus P8P67 Pro Motherboard - really not sure if this is best MOBO for the best OC
3. 16 G RAM - not sure which RAM
4. Really don't know enough about water cooling but EK's site looks cool. The case above has a bunch of water cooling installed turnkey.
5. Corsair HX 1050 Modular 1050W PSU - not sure if this is enough power for the 2 graphics cards and water pumps etc
6. 240GB Corsair Force 3 Solid State Drive for the OS
7. WD Caviar 2G x 3 for 3 secondary HDs
If I can accomplish the impossible and get this kind of OC without masses of noise for cooling the radiators that would be great.
Would love thoughts on components as all the reviews I read limit discussion to certain budgets and do not discuss them in absolute terms.
Best wishes
I was thinking:
Best wishes
