First Build - Need Some Guidance in Choosing Parts
Last response: in Systems
APPROXIMATE PURCHASE DATE: Within the next week
BUDGET RANGE: $1100-1300
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Web/photo editing (dreamweaver/photoshop), video editing, surfing the internet, gaming (very little)
PARTS NOT REQUIRED: Reusing keyboard, mouse, speakers. Already have an unused copy of Vista Business through MSDN.
PREFERRED WEBSITE(S) FOR PARTS: Newegg, TigerDirect
PARTS PREFERENCES: Looking to use i7 920 (or 950) processor but no preference on any other brands
OVERCLOCKING: No / Maybe SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1680 x 1050
ADDITIONAL COMMENTS: I like a side window on the case but it's not essential.
Can you tell me what you think of what I've put together so far?
CASE: COOLER MASTER Storm Sniper $139.99
Power Supply: OCZ ModXStream Pro OCZ700MXSP 700W $59.99 AR
MB: EVGA E758-TR 3-Way SLI $249.99 AR
CPU: Intel Core i7 920 Nehalem 2.66GHz $279.99
MEMORY: OCZ XMP Ready Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 $94.99 AR
CPU COOLER: ZEROtherm Nirvana NV120 $29.99 AR
VIDEO: POWERCOLOR AX4850 1GBD3-PH $104.99 AR
HARD DRIVE: SEAGATE 1tb barracuda 3.5" internal SATA-300 hard drive 7200rpm 32mb $108.63 AC
http://www.mwave.com/mwave/SKUSearch_v3.asp?scriteria=4...
BR/DVD: LG Black 6X BD-R 2X BD-RE 16X DVD+R 6X BD-ROM 4MB Cache SATA Internal Blu-ray Burner $149.99
MONITOR: Acer X223Wbd Black 22" 5ms Widescreen LCD $139.99
OS: VISTA BUSINESS 64-bit
The case you picked out doesn't seem to really have a window? The Centurion 5 has a regular full window, though it is only a mid tower. The Haf 932 seems to have more of a window than the Storm Sniper too.
Perhaps go with this cooler instead. Frostytech had better results with it, and it's cheaper!
I always like Sapphire for my ATI cards, so I'll recommend this Sapphire 4850. It's cheaper too!
As for the drive, ask yourself if you are really going to be burning blu-rays.
If you want a faster hard drive for stuff, you can try a WD Black.
Thanks for your advice. Do you know if the cooler will fit in the Centurion 5 or how I might find out?
Yeah, you're right - I am not going to burn blu-rays and TigerDirect has a blu-ray reader + DVDRW combo for $89 so that saves some money.
I usually just browse through the case reviews and find someone who used a particularly large heatsink, see how tall that heatsink is, and compare to the one I'm interested in.
In this case I see someone said they had 1/4" to spare when using a Xigmatek HDT, which is 159mm tall, the Zerotherm is 156, so it should work.
Ask the community
