Water block for GTX 580?
please help to choose better water block for gtx 580, may be something from here http://www.frozencpu.com/cat/l3/g30/...cks-Page1.html
thank you
5 answers Last reply
More about water block
  1. Is this a reference design or a custom designed card. If non reference then you will most likely run into a few issues with compatibility when choosing a compatible block. If a universal block that does not cover the vram and power vrm you must keep the whole card cool either wise it will not last.
    it is a reference card http://www.evga.com/products/moreInfo.asp?pn=015-P3-1580-AR&family=GeForce%20500%20Series%20Family&sw=
  3. Quote:
    Disagree.
    I've used universal blocks on 5 generations of cards...using the same blocks. You simply need to use RAMsinks on your vRAM modules and decent airflow inside your case. Unless you are really OC'ing your card hard, this setup will work well....and even then, I'm betting the OC is unstable before the card burns up.
  4. rubix_1011 said:
    Disagree.
    I am not talk about the vram but the power vrm on these cards. It take more than small vram coolers to keep the power vrm from degrading unless there is a fan or fans mounted near the rear of the card. The reason why I suggested full cover is to avoid any problems down the road. As for you I know that the first two or three generation cards didn't draw as much power as a gtx 580.
Graphics Cards Gtx Overclocking
