Good Power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Good Power supply
Does Good Branded Power supplies like Thermaltake,Corsair help to increase in PCs performance?If It, Do it have a radical difference
Sponsored Links
Not really. A pc uses a certain amount of current based on total load. Better power supplies have the potential of overclocking the processor higher, but there are no guarantees. If you upgrade your power supply, do it for the right reason: increased stability and overload protection in cased you get zapped during a power failure or lightening strike.
Reply to o1die
No...
Good PSU's don't increase systems performance...
They reduce the chances of hardware failure
They also save electricity as they are usually 85% efficient as compared to the generic ones which are only 60%.
Reply to shubham1401
- 0 +
Get a decent powersupply (ignore the wattage). Seriously, a low quality PSU is likely to end up costing far more by destroying itself and other things than you will save as opposed to getting a good one.
Reply to spuddyt
- 0 +
spuddyt wrote :
Get a decent power supply
True.
spuddyt wrote :
... (ignore the wattage).
You need to select an appropriately sized PSU. For a low spec computer, I suggest a Corsair 400CX. For most medium powered systems with a single video card, something like a 500 - 600 watt Corsair or Antec will work nicely. And someone technically savvy enough to build a big system with a bunch of HD's or multiple video cards can select his own. (I recommend Corsair and Antec because those are the two brands that I have the most experience with.
spuddyt wrote :
Seriously, a low quality PSU is likely to end up costing far more by destroying itself and other things ...
Low quality power supplies frequently fail catastrophically, "catastrophically" being defined as exploding or bursting into flames.
Message edited by jsc on 10-24-2009 at 02:30:26 PM
Reply to jsc
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Good Power supply
There are 1036 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
